    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    452 Posts 111 Posters 596.4k Views 112 Watching
    • samuel_tS Offline
      samuel_t
      @EarthMover I can import with my plugin your DAE model in SketchUp Make 2017 on Windows 10:
      In your last screenshot, there are some well written files in your "tmp" directory. I don't understand...
        Rick959
        Hi there,
        I have installed your plugin and when I try to import a model, I have tried several different models, I get the same error each time.
        Please see the image attached.
        Thanks in advance
        • samuel_tS Offline
          samuel_t
          @rick959 said:
          Hi there,
          Thanks in advance
          Hi Rick,
          (Re)install Microsoft Visual C++ library then try again.
          • P Offline
            Please dell me
            I want to try it, you say it FREE, bud if I instal it, I have jsut one icon - DONATE and then open PayPall. So itยดs free, but you must pay ?
            Realy thanks to waste 10 minutes to download and instal and unistaling again ๐Ÿ˜ž
              Not sure what you installed that you ended up with an icon that points to PayPal?
              This tool exists in the File menu if properly installed.
              Sounds like PEBKAC to me.
              • samuel_tS Offline
                samuel_t
                Ahh too bad, you were so close! ๐Ÿ˜„ In SketchUp menu, select: File > Import with Universal Importer... It will cost nothing but a few clicks ๐Ÿ˜‰
                • samuel_tS Offline
                  samuel_t
                  It's true but, in current version, there's also a Donate entry in Plugins menu. To avoid confusion, in next version, I will add an Import entry in Plugins menu too.
                    SreckoM
                    Is it possible to keep parts separated, as groups or components, when importing formats like obj, fbx of Collada? Right now it imports everything as a single mesh.
                    • samuel_tS Offline
                      samuel_t
                      I think it's doable but I don't know how yet... Your request has been added to my todo list.
                        tonytony321
                        Hi there, appreciate the effort!
                        I have been trying to use it on obj and 3ds file, but it keeps showing error
                        Universal Importer Error: invalid byte sequence in UTF-8
                        Any idea how to solve this? Thank you
                        • samuel_tS Offline
                          samuel_t
                          Does your input model filename or path contain non-ASCII characters?
                            maxicus
                            Problem with dxf files
                            When I try to import a dxf file no error occurs and SU recognises the dxf file as a new component, but there is no content!
                            I get a prompt to place the import, but then there is nothing there.
                            Any idea what might be wrong?
                            Many thanks,
                            Max
                            • samuel_tS Offline
                              samuel_t
                              @arakon said:
                              Found an issue with "small" models.
                              Example: I'm importing a functional model that is 95x46x75.45mm in size. The STL is 75.45 tall, however, in order for it to import semi-properly, I have to use the 46mm as height.
                              However, the model, when imported, is actually 99.12x47.99x78.72mm in size, so it's actually 104.3261% of the original size in all directions.
                              If I import it at a factor of 100 (telling it that the STL is 4600mm in height), then downscale it to 0.01 in Sketchup, the size is correct.
                              Sorry for the late reply. Thanks for your report. Universal Importer plugin contains too many hacks (scaling is one of them). This plugin needs a partial or full rewrite, but I can't promise it will happen.
                              • samuel_tS Offline
                                samuel_t
                                Many thanks,
                                Max
                                Can you please send us the DXF file you try to import?
                                  RBC60HzVolts
                                  Am I missing something? I followed the steps in the video (I think anyway) and all I can get is the mesh. I tried several times with an export from Blender - just mesh. Tried a stock obj file "Lego man" - same thing even when opening the jpg & png files. I tried uninstall the re-install (only wat I could find was Extension manager (just a clue after one of your comment replies).
                                  • samuel_tS Offline
                                    samuel_t
                                    It seems to me glTF import works better. Try to export your model to a .gltf file from Blender then import this .gltf file into SketchUp with Universal Importer plugin.
                                      sketchgirl1
                                      Hello: I downloaded it but when I click on it, the computer asks how I want to open it. What do I do now? I have Windows 11 and SketchUp 2017. Thanks.
                                        Use SketchUp to install it. You can't open .rbz files
                                          You don't 'open' an RBZ file.
                                          You 'save' it onto your computer.
                                          Make sure your web-browser is set up to do this...
                                          When you have your RBZ in your Downloads folder you need to 'install' the RBZ's contents.
                                          Open SketchUp and use the Extension Manager - it's menu location depends on the SketchUp version.
                                          In the dialog that opens there's a button 'Install Extension...'
                                          Click that, find the saved RBZ and SketchUp does the rest to it, and extracts its contents into your Plugins folder etc...
                                            sketchgirl1
                                            Okay I got it (Universal importer) showing up in extensions but when I click it it sends me to a donation page. I guess that means I must donate a dollar? I just tried free (for 15 days) FluidImporterPro and my SketchUp program crashed when I tried to import an FBX file chair. I have SketchUp 2017. Not sure how I know this one (Universal importer) will work. Maybe I might as well buy SimLab Obj Importer since that is already installed, from my free trial, and I know it works. Thank you.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
