    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
    • samuel_tS
      samuel_t
      @rick959 said:
      Hi there,
      I have installed your plugin and when I try to import a model, I have tried several different models, I get the same error each time.
      Please see the image attached.
      Thanks in advance
      Hi Rick,
      (Re)install Microsoft Visual C++ library then try again.
      • P
        Please dell me
        I want to try it, you say it FREE, bud if I instal it, I have jsut one icon - DONATE and then open PayPall. So itยดs free, but you must pay ?
        Realy thanks to waste 10 minutes to download and instal and unistaling again ๐Ÿ˜ž
          Not sure what you installed that you ended up with an icon that points to PayPal?
          This tool exists in the File menu if properly installed.
          Sounds like PEBKAC to me.
          • samuel_tS
            samuel_t
            Ahh too bad, you were so close! ๐Ÿ˜„ In SketchUp menu, select: File > Import with Universal Importer... It will cost nothing but a few clicks ๐Ÿ˜‰
            • samuel_tS
              samuel_t
              It's true but, in current version, there's also a Donate entry in Plugins menu. To avoid confusion, in next version, I will add an Import entry in Plugins menu too.
                SreckoM
                Is it possible to keep parts separated, as groups or components, when importing formats like obj, fbx of Collada? Right now it imports everything as a single mesh.
                • samuel_tS
                  samuel_t
                  I think it's doable but I don't know how yet... Your request has been added to my todo list.
                  • T
                    tonytony321
                    Hi there, appreciate the effort!
                    I have been trying to use it on obj and 3ds file, but it keeps showing error
                    Universal Importer Error: invalid byte sequence in UTF-8
                    Any idea how to solve this? Thank you
                    • samuel_tS
                      samuel_t
                      Does your input model filename or path contain non-ASCII characters?
                        maxicus
                        Problem with dxf files
                        When I try to import a dxf file no error occurs and SU recognises the dxf file as a new component, but there is no content!
                        I get a prompt to place the import, but then there is nothing there.
                        Any idea what might be wrong?
                        Many thanks,
                        Max
                        • samuel_tS
                          samuel_t
                          @arakon said:
                          Found an issue with "small" models.
                          Example: I'm importing a functional model that is 95x46x75.45mm in size. The STL is 75.45 tall, however, in order for it to import semi-properly, I have to use the 46mm as height.
                          However, the model, when imported, is actually 99.12x47.99x78.72mm in size, so it's actually 104.3261% of the original size in all directions.
                          If I import it at a factor of 100 (telling it that the STL is 4600mm in height), then downscale it to 0.01 in Sketchup, the size is correct.
                          Sorry for the late reply. Thanks for your report. Universal Importer plugin contains too many hacks (scaling is one of them). This plugin needs a partial or full rewrite, but I can't promise it will happen.
                          • samuel_tS
                            samuel_t
                            Many thanks,
                            Max
                            Can you please send us the DXF file you try to import?
                              RBC60HzVolts
                              Am I missing something? I followed the steps in the video (I think anyway) and all I can get is the mesh. I tried several times with an export from Blender - just mesh. Tried a stock obj file "Lego man" - same thing even when opening the jpg & png files. I tried uninstall the re-install (only wat I could find was Extension manager (just a clue after one of your comment replies).
                              • samuel_tS
                                samuel_t
                                It seems to me glTF import works better. Try to export your model to a .gltf file from Blender then import this .gltf file into SketchUp with Universal Importer plugin.
                                  sketchgirl1
                                  Hello: I downloaded it but when I click on it, the computer asks how I want to open it. What do I do now? I have Windows 11 and SketchUp 2017. Thanks.
                                    Use SketchUp to install it. You can't open .rbz files
                                      You don't 'open' an RBZ file.
                                      You 'save' it onto your computer.
                                      Make sure your web-browser is set up to do this...
                                      When you have your RBZ in your Downloads folder you need to 'install' the RBZ's contents.
                                      Open SketchUp and use the Extension Manager - it's menu location depends on the SketchUp version.
                                      In the dialog that opens there's a button 'Install Extension...'
                                      Click that, find the saved RBZ and SketchUp does the rest to it, and extracts its contents into your Plugins folder etc...
                                        sketchgirl1
                                        Okay I got it (Universal importer) showing up in extensions but when I click it it sends me to a donation page. I guess that means I must donate a dollar? I just tried free (for 15 days) FluidImporterPro and my SketchUp program crashed when I tried to import an FBX file chair. I have SketchUp 2017. Not sure how I know this one (Universal importer) will work. Maybe I might as well buy SimLab Obj Importer since that is already installed, from my free trial, and I know it works. Thank you.
                                          sketchgirl1
                                          Not sure exactly how to reply to your post in the right order. But anyway I finally imported my FBX chair file with Skimp importer, which worked very well. But it's expensive (a yearly charge of $80 I think - Simlab is that much for permanent license). But free for 5 days. So I guess this Universal Importer is a good option. I would just like to know, is that true that I must donate and then the importer will be accessible (the words "import" will show up when I press Universal extension, under extensions tab?) Thank you.
                                            No, the tool resides under the File menu. The donation to Samuel is in the Extensions menu.
                                            Donation are entirely up to the user.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
