    [Plugin] Random Entity Generator - v1.2.1 - 29 April 2025
    41 Posts 9 Posters 22.7k Views 9 Watching
    • samuel_tS Offline
      samuel_t
      With 1.1.3 version:
      You can set Random Zone from an image. Here is how. Note: SketchUp 2018 or greater is required.
      REG Plugin Star Scattering Map
      REG Plugin Star Demo
      Download latest REG plugin from the SketchUcation PluginStore.
      • samuel_tS Offline
        samuel_t
        1.1.4 version enhances compatibility and performance for "Set Random Zone from Image" feature. Now, this feature is compatible with SketchUp 2017 or newer and is a lot faster.
        • samuel_tS Offline
          samuel_t
          @pbacot said:
          I think it's amazing you can make it work with Enscape and all. [...]
          It also works with V-Ray and potentially other renderers. πŸ˜„ πŸ‘
          Just randomize the component-proxy made with V-Ray/other...
          (Right click on component-proxy then left click "Randomize...".)
          • samuel_tS Offline
            samuel_t
            1.0.7 version:
            • Adds four parameters:
              • Entity minimum rotation
              • Entity maximum rotation
              • Follow face normals?*
              • Overwrite entity colors?
            • Supports multiple Random Zones.
            (*) Thanks to Eneroth3 for its help.
            REG Plugin Glue To Faces Demo
            • samuel_tS Offline
              samuel_t
              1.1.5 version adds three parameters:
              • When you set selection as Random Zone:
                • Entity distribution algorithm
              • When you set Random Zone from an image:
                • How many vertical (Z axis) layers?
                • Space between each Z layer (cm)?
              • samuel_tS Offline
                samuel_t
                1.1.6 version adds two parameters:
                • Put entities in group
                • Put entities in layer
                Download latest Random Entity Generator plugin from the SketchUcation PluginStore.
                • samuel_tS Offline
                  samuel_t
                  1.1.7 version fixes a bug concerning scaling.
                  • Didier BurD Offline
                    Didier Bur
                    It seems you're re-doing Compo Spray ? πŸ˜„
                    SketchUp Extension Warehouse
                    Your library of custom third-party extensions created to optimize your SketchUp workflow.
                    (extensions.sketchup.com)
                    DB
                    • samuel_tS Offline
                      samuel_t
                      @didier bur said:
                      Hi. You're right Didier. They're similar. πŸ˜‰
                      • K Offline
                        kenancakir
                        Thank you..
                        • samuel_tS Offline
                          samuel_t
                          1.1.8 version memorizes user settings.
                          • OxerO Offline
                            Oxer
                            Spanish Language FIle
                            es.zip
                            [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
                            • samuel_tS Offline
                              samuel_t
                              [attachment=0:3osii3uy]<!-- ia0 -->es.zip<!-- ia0 -->[/attachment:3osii3uy]
                              Thank you!
                              • K Offline
                                Kruegen
                                This extension is amazing! I use this all the time in our workflow we have for quickly dispersing trees along terrain. I am having a lot of trouble getting the "Set Random Zone from Image..." function to work. I can select the image, and type in the parameters for centimeters per pixel, etc. but once i select OK the following error message pops up:
                                Error: undefined method 'unpack' for nil:NilClass
                                Is there any way you could help me with this? This extension is amazing, and the function of Set Random Zone from Image would be a giant help to our team. Thanks Samuel!
                                • samuel_tS Offline
                                  samuel_t
                                  This extension is only compatible with 24-bit BMP images. So be sure to select a 24-bit BMP image...
                                  • K Offline
                                    Kruegen
                                    Thanks! that solved my issue
                                    • samuel_tS Offline
                                      samuel_t
                                      1.1.9 version adds spanish translation. Thanks Γ“scar HernΓ‘ndez (Oxer) for this translation!
                                      • samuel_tS Offline
                                        samuel_t
                                        1.2.0 version allows you to use the proxy library of this plugin in SketchUp 2017 or newer.
                                        • P Offline
                                          Pavol Ivanko Newcomers
                                          Samuel can you help?
                                          Extension Errors Report
                                          SketchUp: 24.0.594
                                          OS: Windows 10
                                          Ruby: 3.2.2
                                          does the extension work on sketchup 2024?
                                          samuel_tS 1 Reply Last reply Reply Quote 0
                                          • samuel_tS Offline
                                            samuel_t @Pavol Ivanko
                                            @Pavol-Ivanko
                                            Thanks for your report! I identified the issue, and it's super easy to fix.
                                            I will push a new version of this extension compatible with SU 2024+.
                                            • 2 / 3
