    [Plugin] Random Entity Generator - v1.2.1 - 29 April 2025
    41 Posts 9 Posters 22.7k Views 9 Watching
    • samuel_tS Offline
      samuel_t
      1.1.4 version enhances compatibility and performance for "Set Random Zone from Image" feature. Now, this feature is compatible with SketchUp 2017 or newer and is a lot faster.
      Download latest REG plugin from the SketchUcation PluginStore.
      • samuel_tS Offline
        samuel_t
        @pbacot said:
        I think it's amazing you can make it work with Enscape and all. [...]
        It also works with V-Ray and potentially other renderers. πŸ˜„ πŸ‘
        Just randomize the component-proxy made with V-Ray/other...
        (Right click on component-proxy then left click "Randomize...".)
        • samuel_tS Offline
          samuel_t
          1.0.7 version:
          • Adds four parameters:
            • Entity minimum rotation
            • Entity maximum rotation
            • Follow face normals?*
            • Overwrite entity colors?
          • Supports multiple Random Zones.
          (*) Thanks to Eneroth3 for its help.
          REG Plugin Glue To Faces Demo
          • samuel_tS Offline
            samuel_t
            1.1.5 version adds three parameters:
            • When you set selection as Random Zone:
              • Entity distribution algorithm
            • When you set Random Zone from an image:
              • How many vertical (Z axis) layers?
              • Space between each Z layer (cm)?
            • samuel_tS Offline
              samuel_t
              1.1.6 version adds two parameters:
              • Put entities in group
              • Put entities in layer
              Download latest Random Entity Generator plugin from the SketchUcation PluginStore.
              • samuel_tS Offline
                samuel_t
                1.1.7 version fixes a bug concerning scaling.
                • Didier BurD Offline
                  Didier Bur
                  It seems you're re-doing Compo Spray ? πŸ˜„
                  SketchUp Extension Warehouse
                  Your library of custom third-party extensions created to optimize your SketchUp workflow.
                  (extensions.sketchup.com)
                  DB
                  • samuel_tS Offline
                    samuel_t
                    @didier bur said:
                    Hi. You're right Didier. They're similar. πŸ˜‰
                      kenancakir
                      Thank you..
                      • samuel_tS Offline
                        samuel_t
                        1.1.8 version memorizes user settings.
                        • OxerO Offline
                          Oxer
                          Spanish Language FIle
                          es.zip
                          • samuel_tS Offline
                            samuel_t
                            [attachment=0:3osii3uy]<!-- ia0 -->es.zip<!-- ia0 -->[/attachment:3osii3uy]
                            Thank you!
                              Kruegen
                              This extension is amazing! I use this all the time in our workflow we have for quickly dispersing trees along terrain. I am having a lot of trouble getting the "Set Random Zone from Image..." function to work. I can select the image, and type in the parameters for centimeters per pixel, etc. but once i select OK the following error message pops up:
                              Error: undefined method 'unpack' for nil:NilClass
                              Is there any way you could help me with this? This extension is amazing, and the function of Set Random Zone from Image would be a giant help to our team. Thanks Samuel!
                              • samuel_tS Offline
                                samuel_t
                                This extension is only compatible with 24-bit BMP images. So be sure to select a 24-bit BMP image...
                                  Kruegen
                                  Thanks! that solved my issue
                                  • samuel_tS Offline
                                    samuel_t
                                    1.1.9 version adds spanish translation. Thanks Γ“scar HernΓ‘ndez (Oxer) for this translation!
                                    • samuel_tS Offline
                                      samuel_t
                                      1.2.0 version allows you to use the proxy library of this plugin in SketchUp 2017 or newer.
                                        Pavol Ivanko Newcomers
                                        Samuel can you help?
                                        Extension Errors Report
                                        SketchUp: 24.0.594
                                        OS: Windows 10
                                        Ruby: 3.2.2
                                        does the extension work on sketchup 2024?
                                        samuel_tS 1 Reply Last reply Reply Quote 0
                                        • samuel_tS Offline
                                          samuel_t @Pavol Ivanko
                                          @Pavol-Ivanko
                                          Thanks for your report! I identified the issue, and it's super easy to fix.
                                          I will push a new version of this extension compatible with SU 2024+.
                                          • samuel_tS Offline
                                            samuel_t
                                            1.2.1 version:
                                            • Brings compatibility with SketchUp 2024 & 2025.
                                            • Tries to avoid conflicts with Fredo6's LOTT plugin.
                                            • 2 / 3
