    [Plugin] Random Entity Generator - v1.2.1 - 29 April 2025
    41 Posts 9 Posters 22.3k Views 9 Watching
    • samuel_tS Offline
      samuel_t
      @didier bur said:
      It seems you're re-doing Compo Spray ? 😄
      SketchUp Extension Warehouse
      Your library of custom third-party extensions created to optimize your SketchUp workflow.
      (extensions.sketchup.com)
      Hi. You're right Didier. They're similar. 😉
        kenancakir
        Thank you..
        • samuel_tS Offline
          samuel_t
          1.1.8 version memorizes user settings.
          Download latest Random Entity Generator plugin from the SketchUcation PluginStore.
          • OxerO Offline
            Oxer
            Spanish Language FIle
            es.zip
            • samuel_tS Offline
              samuel_t
              [attachment=0:3osii3uy]<!-- ia0 -->es.zip<!-- ia0 -->[/attachment:3osii3uy]
              Thank you!
                Kruegen
                This extension is amazing! I use this all the time in our workflow we have for quickly dispersing trees along terrain. I am having a lot of trouble getting the "Set Random Zone from Image..." function to work. I can select the image, and type in the parameters for centimeters per pixel, etc. but once i select OK the following error message pops up:
                Error: undefined method 'unpack' for nil:NilClass
                Is there any way you could help me with this? This extension is amazing, and the function of Set Random Zone from Image would be a giant help to our team. Thanks Samuel!
                • samuel_tS Offline
                  samuel_t
                  This extension is only compatible with 24-bit BMP images. So be sure to select a 24-bit BMP image...
                    Kruegen
                    Thanks! that solved my issue
                    • samuel_tS Offline
                      samuel_t
                      1.1.9 version adds spanish translation. Thanks Óscar Hernández (Oxer) for this translation!
                      • samuel_tS Offline
                        samuel_t
                        1.2.0 version allows you to use the proxy library of this plugin in SketchUp 2017 or newer.
                          Pavol Ivanko Newcomers
                          Samuel can you help?
                          Extension Errors Report
                          SketchUp: 24.0.594
                          OS: Windows 10
                          Ruby: 3.2.2
                          does the extension work on sketchup 2024?
                          samuel_tS 1 Reply Last reply Reply Quote 0
                          • samuel_tS Offline
                            samuel_t @Pavol Ivanko
                            @Pavol-Ivanko
                            Thanks for your report! I identified the issue, and it's super easy to fix.
                            I will push a new version of this extension compatible with SU 2024+.
                            • samuel_tS Offline
                              samuel_t
                              1.2.1 version:
                              • Brings compatibility with SketchUp 2024 & 2025.
                              • Tries to avoid conflicts with Fredo6's LOTT plugin.
                              • 2 / 3
