    [Plugin] Random Entity Generator - v1.2.1 - 29 April 2025
    41 Posts 9 Posters 22.7k Views 9 Watching
    • samuel_tS Offline
      samuel_t
      1.0.8 version fixes a bug about entity rotation.
      Download latest REG plugin from the SketchUcation PluginStore.
      • samuel_tS Offline
        samuel_t
        1.0.9 version includes a library of proxies ready-to-use for Enscape and V-Ray. (It's available on Windows only.)
        REG Proxy Library
        REG Plugin Proxy Library Demo
        • samuel_tS Offline
          samuel_t
          1.1.0 version:
          • Adds a parameter: Entity max. altitude.
          • Handles complex meshes very quickly:
            A FlowScape challenger! ๐Ÿ˜‰
            • samuel_tS Offline
              samuel_t
              1.1.1 version:
              • Adds a parameter useful e.g. to hide tree roots: Push entities to down (cm).
              • Adds four presets to help you discover how parameters work in REG plugin.
              • samuel_tS Offline
                samuel_t
                What's new in 1.1.2 version?
                • There is a "Preview" button in REG Parameters.
                • Random Zones can be constituted of triangles.
                • samuel_tS Offline
                  samuel_t
                  With 1.1.3 version:
                  You can set Random Zone from an image. Here is how. Note: SketchUp 2018 or greater is required.
                  REG Plugin Star Scattering Map
                  REG Plugin Star Demo
                  • samuel_tS Offline
                    samuel_t
                    1.1.4 version enhances compatibility and performance for "Set Random Zone from Image" feature. Now, this feature is compatible with SketchUp 2017 or newer and is a lot faster.
                    • samuel_tS Offline
                      samuel_t
                      @pbacot said:
                      I think it's amazing you can make it work with Enscape and all. [...]
                      It also works with V-Ray and potentially other renderers. ๐Ÿ˜„ ๐Ÿ‘
                      Just randomize the component-proxy made with V-Ray/other...
                      (Right click on component-proxy then left click "Randomize...".)
                      • samuel_tS Offline
                        samuel_t
                        1.0.7 version:
                        • Adds four parameters:
                          • Entity minimum rotation
                          • Entity maximum rotation
                          • Follow face normals?*
                          • Overwrite entity colors?
                        • Supports multiple Random Zones.
                        (*) Thanks to Eneroth3 for its help.
                        REG Plugin Glue To Faces Demo
                        • samuel_tS Offline
                          samuel_t
                          1.1.5 version adds three parameters:
                          • When you set selection as Random Zone:
                            • Entity distribution algorithm
                          • When you set Random Zone from an image:
                            • How many vertical (Z axis) layers?
                            • Space between each Z layer (cm)?
                          • samuel_tS Offline
                            samuel_t
                            1.1.6 version adds two parameters:
                            • Put entities in group
                            • Put entities in layer
                            Download latest Random Entity Generator plugin from the SketchUcation PluginStore.
                            • samuel_tS Offline
                              samuel_t
                              1.1.7 version fixes a bug concerning scaling.
                              • Didier BurD Offline
                                Didier Bur
                                It seems you're re-doing Compo Spray ? ๐Ÿ˜„
                                SketchUp Extension Warehouse
                                Your library of custom third-party extensions created to optimize your SketchUp workflow.
                                (extensions.sketchup.com)
                                DB
                                • samuel_tS Offline
                                  samuel_t
                                  @didier bur said:
                                  Hi. You're right Didier. They're similar. ๐Ÿ˜‰
                                    kenancakir
                                    Thank you..
                                    • samuel_tS Offline
                                      samuel_t
                                      1.1.8 version memorizes user settings.
                                      • OxerO Offline
                                        Oxer
                                        Spanish Language FIle
                                        es.zip
                                        • samuel_tS Offline
                                          samuel_t
                                          [attachment=0:3osii3uy]<!-- ia0 -->es.zip<!-- ia0 -->[/attachment:3osii3uy]
                                          Thank you!
                                            Kruegen
                                            This extension is amazing! I use this all the time in our workflow we have for quickly dispersing trees along terrain. I am having a lot of trouble getting the "Set Random Zone from Image..." function to work. I can select the image, and type in the parameters for centimeters per pixel, etc. but once i select OK the following error message pops up:
                                            Error: undefined method 'unpack' for nil:NilClass
                                            Is there any way you could help me with this? This extension is amazing, and the function of Set Random Zone from Image would be a giant help to our team. Thanks Samuel!
                                            • 2 / 3
