    [Plugin] Random Entity Generator - v1.2.1 - 29 April 2025
    41 Posts 9 Posters 23.9k Views 9 Watching
    • samuel_tS Offline
      samuel_t
      1.0.9 version includes a library of proxies ready-to-use for Enscape and V-Ray. (It's available on Windows only.)
      REG Proxy Library
      REG Plugin Proxy Library Demo
      Download latest REG plugin from the SketchUcation PluginStore.
      • samuel_tS Offline
        samuel_t
        1.1.0 version:
        • Adds a parameter: Entity max. altitude.
        • Handles complex meshes very quickly:
          A FlowScape challenger! πŸ˜‰
          • samuel_tS Offline
            samuel_t
            1.1.1 version:
            • Adds a parameter useful e.g. to hide tree roots: Push entities to down (cm).
            • Adds four presets to help you discover how parameters work in REG plugin.
            • samuel_tS Offline
              samuel_t
              What's new in 1.1.2 version?
              • There is a "Preview" button in REG Parameters.
              • Random Zones can be constituted of triangles.
              • samuel_tS Offline
                samuel_t
                With 1.1.3 version:
                You can set Random Zone from an image. Here is how. Note: SketchUp 2018 or greater is required.
                REG Plugin Star Scattering Map
                REG Plugin Star Demo
                • samuel_tS Offline
                  samuel_t
                  1.1.4 version enhances compatibility and performance for "Set Random Zone from Image" feature. Now, this feature is compatible with SketchUp 2017 or newer and is a lot faster.
                  • samuel_tS Offline
                    samuel_t
                    @pbacot said:
                    I think it's amazing you can make it work with Enscape and all. [...]
                    It also works with V-Ray and potentially other renderers. πŸ˜„ πŸ‘
                    Just randomize the component-proxy made with V-Ray/other...
                    (Right click on component-proxy then left click "Randomize...".)
                    • samuel_tS Offline
                      samuel_t
                      1.0.7 version:
                      • Adds four parameters:
                        • Entity minimum rotation
                        • Entity maximum rotation
                        • Follow face normals?*
                        • Overwrite entity colors?
                      • Supports multiple Random Zones.
                      (*) Thanks to Eneroth3 for its help.
                      REG Plugin Glue To Faces Demo
                      • samuel_tS Offline
                        samuel_t
                        1.1.5 version adds three parameters:
                        • When you set selection as Random Zone:
                          • Entity distribution algorithm
                        • When you set Random Zone from an image:
                          • How many vertical (Z axis) layers?
                          • Space between each Z layer (cm)?
                        • samuel_tS Offline
                          samuel_t
                          1.1.6 version adds two parameters:
                          • Put entities in group
                          • Put entities in layer
                          Download latest Random Entity Generator plugin from the SketchUcation PluginStore.
                          • samuel_tS Offline
                            samuel_t
                            1.1.7 version fixes a bug concerning scaling.
                            • Didier BurD Offline
                              Didier Bur
                              It seems you're re-doing Compo Spray ? πŸ˜„
                              SketchUp Extension Warehouse
                              Your library of custom third-party extensions created to optimize your SketchUp workflow.
                              (extensions.sketchup.com)
                              DB
                              • samuel_tS Offline
                                samuel_t
                                @didier bur said:
                                Hi. You're right Didier. They're similar. πŸ˜‰
                                  kenancakir
                                  Thank you..
                                  • samuel_tS Offline
                                    samuel_t
                                    1.1.8 version memorizes user settings.
                                    • OxerO Offline
                                      Oxer
                                      Spanish Language FIle
                                      es.zip
                                      • samuel_tS Offline
                                        samuel_t
                                        [attachment=0:3osii3uy]<!-- ia0 -->es.zip<!-- ia0 -->[/attachment:3osii3uy]
                                        Thank you!
                                          Kruegen
                                          This extension is amazing! I use this all the time in our workflow we have for quickly dispersing trees along terrain. I am having a lot of trouble getting the "Set Random Zone from Image..." function to work. I can select the image, and type in the parameters for centimeters per pixel, etc. but once i select OK the following error message pops up:
                                          Error: undefined method 'unpack' for nil:NilClass
                                          Is there any way you could help me with this? This extension is amazing, and the function of Set Random Zone from Image would be a giant help to our team. Thanks Samuel!
                                          • samuel_tS Offline
                                            samuel_t
                                            This extension is only compatible with 24-bit BMP images. So be sure to select a 24-bit BMP image...
                                            • 2 / 3
