    [Plugin] Random Entity Generator - v1.2.1 - 29 April 2025
    41 Posts 9 Posters 22.1k Views 9 Watching
      kenancakir
      Thank you..
      • samuel_tS Offline
        samuel_t
        1.1.8 version memorizes user settings.
        Download latest Random Entity Generator plugin from the SketchUcation PluginStore.
        • OxerO Offline
          Oxer
          Spanish Language FIle
          es.zip
          • samuel_tS Offline
            samuel_t
            [attachment=0:3osii3uy]<!-- ia0 -->es.zip<!-- ia0 -->[/attachment:3osii3uy]
            Thank you!
              Kruegen
              This extension is amazing! I use this all the time in our workflow we have for quickly dispersing trees along terrain. I am having a lot of trouble getting the "Set Random Zone from Image..." function to work. I can select the image, and type in the parameters for centimeters per pixel, etc. but once i select OK the following error message pops up:
              Error: undefined method 'unpack' for nil:NilClass
              Is there any way you could help me with this? This extension is amazing, and the function of Set Random Zone from Image would be a giant help to our team. Thanks Samuel!
              • samuel_tS Offline
                samuel_t
                This extension is only compatible with 24-bit BMP images. So be sure to select a 24-bit BMP image...
                  Kruegen
                  Thanks! that solved my issue
                  • samuel_tS Offline
                    samuel_t
                    1.1.9 version adds spanish translation. Thanks Óscar Hernández (Oxer) for this translation!
                    • samuel_tS Offline
                      samuel_t
                      1.2.0 version allows you to use the proxy library of this plugin in SketchUp 2017 or newer.
                        Pavol Ivanko Newcomers
                        Samuel can you help?
                        Extension Errors Report
                        SketchUp: 24.0.594
                        OS: Windows 10
                        Ruby: 3.2.2
                        does the extension work on sketchup 2024?
                        samuel_tS 1 Reply Last reply Reply Quote 0
                        • samuel_tS Offline
                          samuel_t @Pavol Ivanko
                          @Pavol-Ivanko
                          Thanks for your report! I identified the issue, and it's super easy to fix.
                          I will push a new version of this extension compatible with SU 2024+.
                          • samuel_tS Offline
                            samuel_t
                            1.2.1 version:
                            • Brings compatibility with SketchUp 2024 & 2025.
                            • Tries to avoid conflicts with Fredo6's LOTT plugin.
                            • 2 / 3
