    [Plugin] Random Entity Generator - v1.2.1 - 29 April 2025
    41 Posts 9 Posters 24.5k Views 9 Watching
    • samuel_tS
      samuel_t
      1.1.7 version fixes a bug concerning scaling.
      Download latest Random Entity Generator plugin from the SketchUcation PluginStore.
      • Didier BurD
        Didier Bur
        It seems you're re-doing Compo Spray ? ๐Ÿ˜„
        SketchUp Extension Warehouse
        Your library of custom third-party extensions created to optimize your SketchUp workflow.
        (extensions.sketchup.com)
        DB
        • samuel_tS
          samuel_t
          @didier bur said:
          Hi. You're right Didier. They're similar. ๐Ÿ˜‰
          • K
            kenancakir
            Thank you..
            • samuel_tS
              samuel_t
              1.1.8 version memorizes user settings.
              • OxerO
                Oxer
                Spanish Language FIle
                es.zip
                • samuel_tS
                  samuel_t
                  [attachment=0:3osii3uy]<!-- ia0 -->es.zip<!-- ia0 -->[/attachment:3osii3uy]
                  Thank you!
                  • K
                    Kruegen
                    This extension is amazing! I use this all the time in our workflow we have for quickly dispersing trees along terrain. I am having a lot of trouble getting the "Set Random Zone from Image..." function to work. I can select the image, and type in the parameters for centimeters per pixel, etc. but once i select OK the following error message pops up:
                    Error: undefined method 'unpack' for nil:NilClass
                    Is there any way you could help me with this? This extension is amazing, and the function of Set Random Zone from Image would be a giant help to our team. Thanks Samuel!
                    • samuel_tS
                      samuel_t
                      This extension is only compatible with 24-bit BMP images. So be sure to select a 24-bit BMP image...
                      • K
                        Kruegen
                        Thanks! that solved my issue
                        • samuel_tS
                          samuel_t
                          1.1.9 version adds spanish translation. Thanks ร“scar Hernรกndez (Oxer) for this translation!
                          • samuel_tS
                            samuel_t
                            1.2.0 version allows you to use the proxy library of this plugin in SketchUp 2017 or newer.
                            • P
                              Pavol Ivanko Newcomers
                              Samuel can you help?
                              Extension Errors Report
                              SketchUp: 24.0.594
                              OS: Windows 10
                              Ruby: 3.2.2
                              does the extension work on sketchup 2024?
                              samuel_tS 1 Reply Last reply
                              • samuel_tS
                                samuel_t @Pavol Ivanko
                                @Pavol-Ivanko
                                Thanks for your report! I identified the issue, and it's super easy to fix.
                                I will push a new version of this extension compatible with SU 2024+.
                                • samuel_tS
                                  samuel_t
                                  1.2.1 version:
                                  • Brings compatibility with SketchUp 2024 & 2025.
                                  • Tries to avoid conflicts with Fredo6's LOTT plugin.
                                  • 2 / 3
