    Is there a method to "ignore" lines during subdivision
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    9 Posts 5 Posters 10.7k Views 5 Watching
    • N Offline
      Nirajp18
      I am starting to regularly come up with scenarios where I need to introduce quads in opposite directions but when doing so, I need to "quadify" the trunk where the branch is coming off of.
      While there is the creasing function is there something or a method of modeling that acts almost like an "uncrease" where the lines that need to be drawn to "quadify" do not take part in the subdivision?
      Looking for some guidance. Thank you.
        I'm not sure I fully understand what you are asking for?
        Can you illustrate what your expected result would be?
        • N Offline
          Nirajp18
          Hi @thomthom
          thank you so much for your response. I guess I am coming at this question from:
          a) Is there a way to prevent the need to quadify the trunk everytime there is an offshoot
          b) Or even if we quadify the "trunk" can we get the resulting geometry not affected by the lines that were drawn. An "un-crease" of sorts?
          • cottyC Offline
            cotty
            Have you deleted the inner faces in your example?
            Edit: added image
            my SketchUp gallery
            • N Offline
              Nirajp18
              Ahhhh... good call @cotty!!!
              That is what I believe I have been missing all along. Thank you so much.
              • tuna1957T Offline
                tuna1957
                Nirajp18, maybe try it this way.....
                • HornOxxH Offline
                  HornOxx
                  πŸ˜„ this option still remains also
                  never trust a skinny cook
                    There is an option you can enable to have SUbD check the mesh to be manifold:
                    • N Offline
                      Nirajp18
                      So much knowledge! Thank you everyone @thomthom, @hornoxx, @tuna1957, & @cotty! I really appreciate you sharing your expertise.
