Can someone help recover a file?
File size is roughly 66mB
When I attempt to open it after an unscheduled system reboot, it says "Unexpected File Format"
I've tried to import the file into a new file and get the same message.
Thoughts?
Using Sketchup Make 17.2.2555 64bit -
here is the file.
anyone should be able to download the file.
It's probably foobar !
Did SketchUp make a .skb backup file in the same folder ?
If so, try to rename with .skp on the end and try opening that.
If it opens it'll be one save behind.Also look for an AutoSave_FileName.skp file and see if that works...
been a while since i've had to resort to using the skb file.
thanks for the suggestion and refreshing my memory!
Register LoginAdvertisement
