    Can someone help recover a file?
    4 Posts 2 Posters 1.1k Views 2 Watching
      pixelmonkey380
      File size is roughly 66mB
      When I attempt to open it after an unscheduled system reboot, it says "Unexpected File Format"
      I've tried to import the file into a new file and get the same message.
      Thoughts?
      Using Sketchup Make 17.2.2555 64bit
        pixelmonkey380
        here is the file.
        Page Not Found
        Web word processing, presentations and spreadsheets
        (drive.google.com)
        anyone should be able to download the file.
          It's probably foobar !
          Did SketchUp make a .skb backup file in the same folder ?
          If so, try to rename with .skp on the end and try opening that.
          If it opens it'll be one save behind.
          Also look for an AutoSave_FileName.skp file and see if that works...
            pixelmonkey380
            been a while since i've had to resort to using the skb file.
            thanks for the suggestion and refreshing my memory!
