    Can someone help recover a file?
    4 Posts 2 Posters 1.1k Views 2 Watching
    • P
      pixelmonkey380
      File size is roughly 66mB
      When I attempt to open it after an unscheduled system reboot, it says "Unexpected File Format"
      I've tried to import the file into a new file and get the same message.
      Thoughts?
      Using Sketchup Make 17.2.2555 64bit
      • P
        pixelmonkey380
        here is the file.
        Page Not Found
        Web word processing, presentations and spreadsheets
        (drive.google.com)
        anyone should be able to download the file.
          It's probably foobar !
          Did SketchUp make a .skb backup file in the same folder ?
          If so, try to rename with .skp on the end and try opening that.
          If it opens it'll be one save behind.
          Also look for an AutoSave_FileName.skp file and see if that works...
          • P
            pixelmonkey380
            been a while since i've had to resort to using the skb file.
            thanks for the suggestion and refreshing my memory!
