    Transparent overlay.
    8 Posts 4 Posters 1.1k Views 4 Watching
      Looking for the file formats acceptable to sketchup that will display transparent sections. PNG is fine but too big a file.
      • jujuJ Offline
        juju
        I'm probably wrong, but I think the only format that SU accepts with an alpha channel is PNG.
        +++ EDIT +++
        I double checked quickly as I've only ever used PNG's.
        Seems like PSD files are supported, which should have alpha channel support.
          Thanks, much appreciated. PSD files I cannot do rather irritatingly and png is an immense file size (1.7mb). One of those curve balls in life.
            Have you tried re-sampling the PNG file is Gimp / Photoshop to make it smaller ?
            The size you quoted seems very big...
              Thanks, I completely forgot GIMP, I tend to stick to Irfanview for simpler stuff, of which most graphics handling is tbh.
                Not having it, no smaller than 1.7mb. OK, it finally saved the reduced image.
                • G Offline
                  gameongrant
                  Would this work? https://extensions.sketchup.com/en/content/material-resizer
                    Thanks folks, feature mirror available at, https://sketchucation.com/forums/viewtopic.php?f=372&t=70741 .
