    Transparent overlay.
    8 Posts 4 Posters 986 Views 4 Watching
      Looking for the file formats acceptable to sketchup that will display transparent sections. PNG is fine but too big a file.
      • jujuJ Offline
        juju
        I'm probably wrong, but I think the only format that SU accepts with an alpha channel is PNG.
        +++ EDIT +++
        I double checked quickly as I've only ever used PNG's.
        Seems like PSD files are supported, which should have alpha channel support.
          Thanks, much appreciated. PSD files I cannot do rather irritatingly and png is an immense file size (1.7mb). One of those curve balls in life.
          • TIGT Online
            Have you tried re-sampling the PNG file is Gimp / Photoshop to make it smaller ?
            The size you quoted seems very big...
              Thanks, I completely forgot GIMP, I tend to stick to Irfanview for simpler stuff, of which most graphics handling is tbh.
                Not having it, no smaller than 1.7mb. OK, it finally saved the reduced image.
                  gameongrant
                  Would this work? https://extensions.sketchup.com/en/content/material-resizer
                    Thanks folks, feature mirror available at, https://sketchucation.com/forums/viewtopic.php?f=372&t=70741 .
