    Error running ComponentFinder
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    3 Posts 3 Posters 9.1k Views 3 Watching
    • W
      wenzhi1099
      After installing ComponentFinder, I reload the SU, and then prompt error, like this
      Error: C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
      C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/openssl.rb:17:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
      C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/modules/application.rbe:3:in <main>'
      c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:58:in eval' c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:58:in require'
      c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:58:in main' c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:80:in module:FlexTools'
      c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:15:in <module:F3d>' c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:14:in <main>'
      C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in require'
      C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb:22:in register_extension'
      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb:22:in <module:FlexTools>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb:7:in module:F3d'
      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb:6:in <top (required)>' Error: #<NameError: uninitialized constant F3d::FlexTools::Application> c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:76:in main'
      c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:80:in <module:FlexTools>' c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:15:in module:F3d'
      c:/users/administrator/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/f3d_flextools/main.rbe:14:in <main>' C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in eval'
      C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load'
      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb:22:in register_extension' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb:22:in module:FlexTools'
      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb:7:in <module:F3d>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb:6:in <top (required)>'
      how can i fix it?
      thank you
      • halroachH
        halroach
        Hi Wenzhi,
        We have seen this error come up a few times before. Please see the following explanation and solution:
        https://flextools.cc/help/load-error-127/
        FlexTools - Super Quick Windows, Doors, Slats...
        • TIGT
          I am not a FlexTool expert.
          However, there might be a clue in your error message...
          C;/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/f3d_flextools.rb;22;in `register_extension'
          Is your normal Windows user-name 'Administrator' ?
          Usually you'd choose something like 'Wenzhi' ?
          Assuming it is your normal Windows user-name...
          When you initially installed SketchUp did you do it in the proper way ?
          Even if you [as a normal Windows user] have admin-powers you must install complex apps this way...
          [Note that if SketchUp is already installed you should close it, then choose the Repair option offered...]
          Find the SketchUp installer exe file - probably in your downloads folder ?
          Select that exe file's icon.
          Right-click > context-menu > "Run as administrator"
          When prompted choose "Repair" and agree to all prompts thereafter...
          [If it's a fresh install choose "Install" !]
          Installing it in any other way - even if you have full admin-powers is not the same thing.
          Double-clicking on the exe file's icon might 'Run' it, but NOT as 'the administrator'.
          It's not recommended to run SketchUp while logged in as the full 'system-administrator' - but if you have another user-name called [confusingly] 'Administrator', probably with admin-powers that IS OK, BUT you will still need to use "Run as administrator"... as explained...
          If you have really messed up permissions on the C:/Users/Administrator/AppData/Roaming/SketchUp path then you might also need to fix then using Right-click > context-menu > Properties > Security > Edit and ensure that every entry has 'Full Control' set and that this permissions trickles down to apply to all subfolders and files in the tree...
