    Help. How can I get the edges of the two Faces intersecting.
    6 Posts 5 Posters 1.3k Views 5 Watching
    • R
      rastamannichk
      I have this component but there is no edges between the two faces intersection.
      Please tell me what to do. I attached the screen shot.
      • pbacotP
        hard to say. Try show hidden geometry. Try getting all edges and faces onto Layer0.
        • R
          rastamannichk
          I already do it unhide all the edges, I also use Fredo hide/unhide all edges but still no edge.
            Upload the SKP file so we can see exactly what's going on.
            • S
              slbaumgartner
              Also please clarify which two faces you are referring to.
              • TIGT
                Have you set View > Hidden Geometry > ON ?
                That, combined with a Style that displays edges, and has profiles set to show thicker...
                Perhaps used in conjunction with toggling X-ray mode ON/OFF, and also using View > Monochrome mode, to remove visual clutter from any textures etc, and show up any reversed faces...
                These could at least let you see all edges etc...
