    Need a plugin to do this
    extensions
    16 Posts 8 Posters 3.9k Views 8 Watching
    • JonFarJ Offline
      JonFar
      Hi there.
      I was wondering if there is a plugin that can transform this:
      https://i.imgur.com/4BrSMiF.png
      into this:
      https://i.imgur.com/l5K6gSb.png
      WITHOUT having to manualy create a grid and then trim it to the face...
      it's because I have A LOT of these irregular shapes that I need to create internal grids, so that I can create elevations with smoove tools, like this:
      https://i.imgur.com/CEhVl1u.png
      I already tried TIG's Splitup - only works with quad faces, and Quadrilaterizer - doesn't create a regular ortogonal grid...
      So, anyone knows about some plugin that creates a grid only inside an irregular face?
      It would save me a lot of time from having to trim all those grids...
        Generate Ceiling Tile Grid by SDmitch! 😉
        • JonFarJ Offline
          JonFar
          thanks, but that's not it...
          that plugin creates an actual solid ceiling grid
          I need something that only divides the face, with lines
            So try "Floor Generator" same page! 😉
            • pbacotP Offline
              How about Toposhaper. It will put a grid on a flat surface or edges as well as contours
                Else it's not a big deal to make a grid with any orientation and size as you want and make intersection with your surface!
                • JonFarJ Offline
                  JonFar
                  thanks guys, I'll try those plugins
                  the intersect grid with surface solution would be ideal, but when I do that some faces dont get properly created and then this happens:
                  https://i.imgur.com/dY7Rt5W.png
                  strange, right?
                  • pbacotP Offline
                    I've never found intersect faces to be reliable with edges that lie on a face. When the FACES actually intersect is when it works best, so it is called.....
                    Actually I wonder what Pilou is doing in that gif because I can't repeat it.
                    If I were doing it manually, I'd use a smoothed grid, overlay the shape then while smooth remove the unwanted part, while it is smooth--pretty fast. But you say you have a LOT to do so I am not questioning you want it to be as simple as possible. You could make a super grid, all smooth and place ALL your shapes on it at once and select and delete the negative space at once.
                    • cottyC Offline
                      cotty
                      A fast way would be the intersection with such a "grid" component...
                      my SketchUp gallery
                        like this! 😄
                        • Surface = Group "Surface"
                        • Grid = any Grid : Group "Lines" (Grid = A line: Move / Copy, An alone "line" : Move / Copy) = the secret : lines are automatically "themselves intersected" so segments! 😄
                        • Select Group "Lines" : Intersection with Model
                        • Select Group "Lines" : Kill it
                        • Select Group "Surface" : Explode it
                        • Select All : Intersection with Selection : many times if some edges stay "doubled" (second secret) 💚
                          et voilà 😄
                        Maybe all in 3 seconds with little training! 😄
                        Use the OutLiner for easy selection of Groups 🤓
                        • jolranJ Offline
                          jolran
                          Are you going to apply this to a flat/2d face first, and then smoove ? Then Hatchfaces plugin with crosshatching and using a material should create the pattern. I think (?) anyway....
                          • sdmitchS Offline
                            sdmitch
                            strange, right?
                            A common problem when trying to sub-divide a face using edges. You might give my Mesh Maker plugin on my blog page a try. Or better yet Fredo6's ner Face Triangulator!
                            http://sdmitch.blogspot.com/
                            • JonFarJ Offline
                              JonFar
                              Mesh Maker, that's exactly it!
                              thanks all the guys for the help, and Sdmitch for creating this plugin
                              I could do it manually, of course, but this saves me a lot of time 👍 👍 👍
                              • HornOxxH Offline
                                HornOxx
                                ... how about trying it with Soap Skin Bubble ?
                                https://extensions.sketchup.com/de/content/soap-skin-bubble
                                never trust a skinny cook
                                  Mesh maker
                                  missing this one! 😳
                                  • srxS Offline
                                    srx
                                    This looks like a powerful divider https://extensions.sketchup.com/en/content/s4u-divide
                                    www.saurus.rs
