πŸ€‘ 30% Off | Artisan 2 on sale until April 30th Buy Now
Need a plugin to do this
extensions
16 Posts 8 Posters 3.3k Views
    JonFar
    Hi there.
    I was wondering if there is a plugin that can transform this:
    https://i.imgur.com/4BrSMiF.png
    into this:
    https://i.imgur.com/l5K6gSb.png
    WITHOUT having to manualy create a grid and then trim it to the face...
    it's because I have A LOT of these irregular shapes that I need to create internal grids, so that I can create elevations with smoove tools, like this:
    https://i.imgur.com/CEhVl1u.png
    I already tried TIG's Splitup - only works with quad faces, and Quadrilaterizer - doesn't create a regular ortogonal grid...
    So, anyone knows about some plugin that creates a grid only inside an irregular face?
    It would save me a lot of time from having to trim all those grids...
      Generate Ceiling Tile Grid by SDmitch! πŸ˜‰
        JonFar
        thanks, but that's not it...
        that plugin creates an actual solid ceiling grid
        I need something that only divides the face, with lines
          So try "Floor Generator" same page! πŸ˜‰
            How about Toposhaper. It will put a grid on a flat surface or edges as well as contours
              Else it's not a big deal to make a grid with any orientation and size as you want and make intersection with your surface!
                JonFar
                thanks guys, I'll try those plugins
                the intersect grid with surface solution would be ideal, but when I do that some faces dont get properly created and then this happens:
                https://i.imgur.com/dY7Rt5W.png
                strange, right?
                  I've never found intersect faces to be reliable with edges that lie on a face. When the FACES actually intersect is when it works best, so it is called.....
                  Actually I wonder what Pilou is doing in that gif because I can't repeat it.
                  If I were doing it manually, I'd use a smoothed grid, overlay the shape then while smooth remove the unwanted part, while it is smooth--pretty fast. But you say you have a LOT to do so I am not questioning you want it to be as simple as possible. You could make a super grid, all smooth and place ALL your shapes on it at once and select and delete the negative space at once.
                    cotty
                    A fast way would be the intersection with such a "grid" component...
                    my SketchUp gallery
                      like this! πŸ˜„
                      • Surface = Group "Surface"
                      • Grid = any Grid : Group "Lines" (Grid = A line: Move / Copy, An alone "line" : Move / Copy) = the secret : lines are automatically "themselves intersected" so segments! πŸ˜„
                      • Select Group "Lines" : Intersection with Model
                      • Select Group "Lines" : Kill it
                      • Select Group "Surface" : Explode it
                      • Select All : Intersection with Selection : many times if some edges stay "doubled" (second secret) πŸ’š
                        et voilΓ  πŸ˜„
                      Maybe all in 3 seconds with little training! πŸ˜„
                      Use the OutLiner for easy selection of Groups πŸ€“
                        jolran
                        Are you going to apply this to a flat/2d face first, and then smoove ? Then Hatchfaces plugin with crosshatching and using a material should create the pattern. I think (?) anyway....
                          sdmitch
                          strange, right?
                          A common problem when trying to sub-divide a face using edges. You might give my Mesh Maker plugin on my blog page a try. Or better yet Fredo6's ner Face Triangulator!
                          http://sdmitch.blogspot.com/
                            JonFar
                            Mesh Maker, that's exactly it!
                            thanks all the guys for the help, and Sdmitch for creating this plugin
                            I could do it manually, of course, but this saves me a lot of time πŸ‘ πŸ‘ πŸ‘
                            • H Offline
                              HornOxx
                              ... how about trying it with Soap Skin Bubble ?
                              https://extensions.sketchup.com/de/content/soap-skin-bubble
                              never trust a skinny cook
                                Mesh maker
                                missing this one! 😳
                                • srxS Offline
                                  srx
                                  This looks like a powerful divider https://extensions.sketchup.com/en/content/s4u-divide
                                  www.saurus.rs
