    Need a plugin to do this
    extensions
    16 Posts 8 Posters 4.1k Views 8 Watching
      So try "Floor Generator" same page! 😉
      • pbacotP Offline
        How about Toposhaper. It will put a grid on a flat surface or edges as well as contours
          Else it's not a big deal to make a grid with any orientation and size as you want and make intersection with your surface!
          • JonFarJ Offline
            JonFar
            thanks guys, I'll try those plugins
            the intersect grid with surface solution would be ideal, but when I do that some faces dont get properly created and then this happens:
            https://i.imgur.com/dY7Rt5W.png
            strange, right?
            • pbacotP Offline
              I've never found intersect faces to be reliable with edges that lie on a face. When the FACES actually intersect is when it works best, so it is called.....
              Actually I wonder what Pilou is doing in that gif because I can't repeat it.
              If I were doing it manually, I'd use a smoothed grid, overlay the shape then while smooth remove the unwanted part, while it is smooth--pretty fast. But you say you have a LOT to do so I am not questioning you want it to be as simple as possible. You could make a super grid, all smooth and place ALL your shapes on it at once and select and delete the negative space at once.
              • cottyC Offline
                cotty
                A fast way would be the intersection with such a "grid" component...
                my SketchUp gallery
                  like this! 😄
                  • Surface = Group "Surface"
                  • Grid = any Grid : Group "Lines" (Grid = A line: Move / Copy, An alone "line" : Move / Copy) = the secret : lines are automatically "themselves intersected" so segments! 😄
                  • Select Group "Lines" : Intersection with Model
                  • Select Group "Lines" : Kill it
                  • Select Group "Surface" : Explode it
                  • Select All : Intersection with Selection : many times if some edges stay "doubled" (second secret) 💚
                    et voilà 😄
                  Maybe all in 3 seconds with little training! 😄
                  Use the OutLiner for easy selection of Groups 🤓
                  • jolranJ Offline
                    jolran
                    Are you going to apply this to a flat/2d face first, and then smoove ? Then Hatchfaces plugin with crosshatching and using a material should create the pattern. I think (?) anyway....
                    • sdmitchS Offline
                      sdmitch
                      strange, right?
                      A common problem when trying to sub-divide a face using edges. You might give my Mesh Maker plugin on my blog page a try. Or better yet Fredo6's ner Face Triangulator!
                      http://sdmitch.blogspot.com/
                      • JonFarJ Offline
                        JonFar
                        Mesh Maker, that's exactly it!
                        thanks all the guys for the help, and Sdmitch for creating this plugin
                        I could do it manually, of course, but this saves me a lot of time 👍 👍 👍
                        • HornOxxH Offline
                          HornOxx
                          ... how about trying it with Soap Skin Bubble ?
                          https://extensions.sketchup.com/de/content/soap-skin-bubble
                          never trust a skinny cook
                            Mesh maker
                            missing this one! 😳
                            • srxS Offline
                              srx
                              This looks like a powerful divider https://extensions.sketchup.com/en/content/s4u-divide
                              www.saurus.rs
