    Need a plugin to do this
    extensions
    16 Posts 8 Posters 4.1k Views 8 Watching
      Generate Ceiling Tile Grid by SDmitch! 😉
      • JonFarJ Offline
        JonFar
        thanks, but that's not it...
        that plugin creates an actual solid ceiling grid
        I need something that only divides the face, with lines
          So try "Floor Generator" same page! 😉
          • pbacotP Offline
            How about Toposhaper. It will put a grid on a flat surface or edges as well as contours
              Else it's not a big deal to make a grid with any orientation and size as you want and make intersection with your surface!
              • JonFarJ Offline
                JonFar
                thanks guys, I'll try those plugins
                the intersect grid with surface solution would be ideal, but when I do that some faces dont get properly created and then this happens:
                https://i.imgur.com/dY7Rt5W.png
                strange, right?
                • pbacotP Offline
                  I've never found intersect faces to be reliable with edges that lie on a face. When the FACES actually intersect is when it works best, so it is called.....
                  Actually I wonder what Pilou is doing in that gif because I can't repeat it.
                  If I were doing it manually, I'd use a smoothed grid, overlay the shape then while smooth remove the unwanted part, while it is smooth--pretty fast. But you say you have a LOT to do so I am not questioning you want it to be as simple as possible. You could make a super grid, all smooth and place ALL your shapes on it at once and select and delete the negative space at once.
                  • cottyC Offline
                    cotty
                    A fast way would be the intersection with such a "grid" component...
                    my SketchUp gallery
                      like this! 😄
                      • Surface = Group "Surface"
                      • Grid = any Grid : Group "Lines" (Grid = A line: Move / Copy, An alone "line" : Move / Copy) = the secret : lines are automatically "themselves intersected" so segments! 😄
                      • Select Group "Lines" : Intersection with Model
                      • Select Group "Lines" : Kill it
                      • Select Group "Surface" : Explode it
                      • Select All : Intersection with Selection : many times if some edges stay "doubled" (second secret) 💚
                        et voilà 😄
                      Maybe all in 3 seconds with little training! 😄
                      Use the OutLiner for easy selection of Groups 🤓
                      • jolranJ Offline
                        jolran
                        Are you going to apply this to a flat/2d face first, and then smoove ? Then Hatchfaces plugin with crosshatching and using a material should create the pattern. I think (?) anyway....
                        • sdmitchS Offline
                          sdmitch
                          strange, right?
                          A common problem when trying to sub-divide a face using edges. You might give my Mesh Maker plugin on my blog page a try. Or better yet Fredo6's ner Face Triangulator!
                          http://sdmitch.blogspot.com/
                          • JonFarJ Offline
                            JonFar
                            Mesh Maker, that's exactly it!
                            thanks all the guys for the help, and Sdmitch for creating this plugin
                            I could do it manually, of course, but this saves me a lot of time 👍 👍 👍
                            • HornOxxH Offline
                              HornOxx
                              ... how about trying it with Soap Skin Bubble ?
                              https://extensions.sketchup.com/de/content/soap-skin-bubble
                              never trust a skinny cook
                                Mesh maker
                                missing this one! 😳
                                • srxS Offline
                                  srx
                                  This looks like a powerful divider https://extensions.sketchup.com/en/content/s4u-divide
                                  www.saurus.rs
