    Animation lost when exiting Animation tool
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    25 Posts 6 Posters 16.1k Views 6 Watching
      jonorman
      Hi..
      Been testing Fredo`s Animator plugin and find it very cool and useful.. Have one major issue tho.
      I`v seen the tutorials and are trying to make an animation. Editing groups and components, saving start with the position saver, and entering the "Clip editor".
      I make one movement, run the clip, looks nice Ease the movement and are happy.. Save the data (with the plugin save button) and exit tool.
      When i go back and want to edit the clip it is all gone.. It is as Ive never made the movement :smile: The saved position is there but not the movement Iv made πŸ˜•
      Any suggestion on what I`m doing wrong ??
      I have SU 2018 with the latest Animator and Fredo lib πŸ˜„
      Thank you..
      Edit:
      The Animator (.animator) file is looking good It has a lot of text in it (opend with notepad to have a look πŸ˜„ )
      • fredo6F Offline
        fredo6
        Normally, the Save button in Animator also save the Sketchup file.
        However, since all changes are in the undo stack (storage as attributes in the model), you may have unsaved if you used the Undo button after exiting Animator.
        All data are saved in the model. A copy is done in the external .animator file at the same time, but it's really for accident. Normally, when you start Animator, it checks which of the model attributes or animator file is the most recent and prompt you if there is a difference.
        Note that the model is self-sufficient as it contains all data of the animation.
        I don't know exactly why you lost data, but may be related to the case I mentioned.
        Fredo
          jonorman
          This only happens on my workstation at work. Iv tried it at home and here it works just fine.. I recon this may be an installation issue of som sort.. Ill try uninstall and reinstall the plugin and the LibFredo library to see if this sorts out the issue..
            jonorman
            Good morning Fredo6 πŸ˜„
            Well, the installation theory i had, seemed to not be correct.. I uninstalled both Animator and FredoLib and reinstalled them both with latest version..
            So i start SU, save the model as i.e Animator test. I make a cube, turn it in to a group, then start Animator. After completing the animation, and when i want to go edit it, it is all gone. Like I did not save it or something. I`v added a Gif video to show the process πŸ˜„
            When using animator at home on a laptop, it works just fine πŸ˜„
            • fredo6F Offline
              fredo6
              @jonorman
              Seems like there is a bug somewhere.
              Could you turn on the Ruby Console and see if there are errors showing up.
              Fredo
                Charlie__V
                I noticed in the .gif when you save the animation and before exit the name of the (clip?) is Film 1...see first screen grab
                Clip name = β€œFilm”
                After you re-start Animator the β€œname” is Film (new).....she second screen grab.
                Clip name = Film (new)
                I haven’t used animator for a month or more, and not by no means an expert......but is your β€œFilm 1” perhaps available in the drop down?
                Charlie
                  jonorman
                  @fredo6 said:
                  @jonorman
                  Fredo
                  Seems to be runing smooth as..!??!.. Well somthing πŸ˜„
                  • P Offline
                    paris_hvac
                    Hi there!
                    I've started recently to use Animator, which i think is an amazing tool, but experienced some bugs.
                    I'm using SU 2018, with latest version of Fredo Library and of Animator. Working on MacOS High Sierra (latest version).
                    The main problems i experienced occurred when trying to create a new view (camera icon): it switches the view to the top view from far out (so far that it is impossible to see the model).
                    It is then impossible to create an animation.
                    The program crashed many times as well.
                    I hope this helps and that you can help
                    Many thanks in advance
                    • fredo6F Offline
                      fredo6
                      1. Could you post or PM to me the model so that I have a look. I don't have a Mac, but maybe I can help.
                      2. For the crashes, do you mean bugsplats with exit from Sketchup?
                      Fredo
                      • fredo6F Offline
                        fredo6
                        Could you do the following:
                        1. Create you animation
                        2. Save it
                        3. Send the model skp file to me before you re-open it, so that I can inspect if the saving went OK.
                        Fredo
                          jonorman
                          Hi Fredo..
                          Started Sketchup, saved file, made animation, saved and exited tool and here it is πŸ˜„ Thank you for your time looking in to this issue.
                          Edit. The ".animator" file was not allowed for uppload
                          Animator test 001.skp
                          • fredo6F Offline
                            fredo6
                            @jonorman said:
                            Hi Fredo..
                            The model does not contain an animation. So very strange...
                            For the .animator file, you can change the extension to .txt. This is just a text file. Then you can attach it.
                            By the way,
                            1. When you save, could you open the Ruby Console before to see if there are error
                            2. Is the place where you save model on hard disk, or on a box-like place?
                            Fredo
                              jonorman
                              Good morning Fredo..
                              Iv made a new anim test... Ruby Console was running the whole time (and nothing showed up there) . Iv saved a copy as at 3 different stages.. After the transition is created and tested but before exiting tool, then after exiting tool, and one last after reopening the tool.
                              Also added the .Animation files. All in a .rar file attached.
                              I save the file on my windows desktop.. πŸ˜„
                              Animation saves .rar
                              • fredo6F Offline
                                fredo6
                                The Animator file is created correctly, but data are not saved to the model file.
                                I need to investigate.
                                Just one additional check. When you save the animation (blue disk button), can you check that in the Undo menu of Sketchup, you have "Animator: Save data".
                                Also, before exiting, could you invoke the Maintenance Dialog box and check that the "sequence 1" is displayed in the list.
                                Fredo
                                  jonorman
                                  Hope i have done it right, added a GIF for observation πŸ˜„
                                  • fredo6F Offline
                                    fredo6
                                    Useful. thanks.
                                    For the Undo, I mean the Sketchup Undo in the Edit menu of Sketchup.
                                    Fredo
                                      jonorman
                                      Good Morning Fredo..
                                      Nope, the undo menu does not have any save data to undo πŸ˜„ Attaced a screendump, and it is the same allwaays, no mather what I do..
                                      • fredo6F Offline
                                        fredo6
                                        I mean Create the animation, Save it from within Animator (so blue disk turns gray) and check the Sketchup Undo label/tooltip.
                                        By the way, could you type the folloiwng command in the Ruby Console:
                                        Sketchup.active_model.path
                                        This should return the file path name of the SKP or nothing.
                                        Fredo
                                          jonorman
                                          Hope I`v done it right now πŸ˜„ Same result as before πŸ˜•
                                          • fredo6F Offline
                                            fredo6
                                            It's a little bit of a mystery!!
                                            I think I have to send you a special version of Animator with traces to see what is going on.
                                            Could you PM me your email address, as the rbz file is above the 2 Mb.
                                            By the way, could you also check in Tools > Fredo6 Collection > Animator > Default_parameters.... that you have set up the auto-save.
                                            Thank you very much
                                            Fredo
                                            • 1 / 2
