    Animation lost when exiting Animation tool
    renderpluginsextensions
    25 Posts 6 Posters 16.8k Views 6 Watching
    • fredo6F
      @jonorman said:
      Seems to be runing smooth as..!??!.. Well somthing πŸ˜„
      Could you do the following:
      1. Create you animation
      2. Save it
      3. Send the model skp file to me before you re-open it, so that I can inspect if the saving went OK.
        jonorman
        Hi Fredo..
        Started Sketchup, saved file, made animation, saved and exited tool and here it is πŸ˜„ Thank you for your time looking in to this issue.
        Edit. The ".animator" file was not allowed for uppload
        Animator test 001.skp
        • fredo6F
          @jonorman said:
          Hi Fredo..
          The model does not contain an animation. So very strange...
          For the .animator file, you can change the extension to .txt. This is just a text file. Then you can attach it.
          By the way,
          1. When you save, could you open the Ruby Console before to see if there are error
          2. Is the place where you save model on hard disk, or on a box-like place?
            jonorman
            Good morning Fredo..
            Iv made a new anim test... Ruby Console was running the whole time (and nothing showed up there) . Iv saved a copy as at 3 different stages.. After the transition is created and tested but before exiting tool, then after exiting tool, and one last after reopening the tool.
            Also added the .Animation files. All in a .rar file attached.
            I save the file on my windows desktop.. πŸ˜„
            Animation saves .rar
            • fredo6F
              The Animator file is created correctly, but data are not saved to the model file.
              I need to investigate.
              Just one additional check. When you save the animation (blue disk button), can you check that in the Undo menu of Sketchup, you have "Animator: Save data".
              Also, before exiting, could you invoke the Maintenance Dialog box and check that the "sequence 1" is displayed in the list.
                jonorman
                Hope i have done it right, added a GIF for observation πŸ˜„
                • fredo6F
                  Useful. thanks.
                  For the Undo, I mean the Sketchup Undo in the Edit menu of Sketchup.
                    jonorman
                    Good Morning Fredo..
                    Nope, the undo menu does not have any save data to undo πŸ˜„ Attaced a screendump, and it is the same allwaays, no mather what I do..
                    • fredo6F
                      I mean Create the animation, Save it from within Animator (so blue disk turns gray) and check the Sketchup Undo label/tooltip.
                      By the way, could you type the folloiwng command in the Ruby Console:
                      Sketchup.active_model.path
                      This should return the file path name of the SKP or nothing.
                        jonorman
                        Hope I`v done it right now πŸ˜„ Same result as before πŸ˜•
                        • fredo6F
                          It's a little bit of a mystery!!
                          I think I have to send you a special version of Animator with traces to see what is going on.
                          Could you PM me your email address, as the rbz file is above the 2 Mb.
                          By the way, could you also check in Tools > Fredo6 Collection > Animator > Default_parameters.... that you have set up the auto-save.
                          Thank you very much
                            jonorman
                            Autosave and confirm Temp exit both checked. Will send you a PM later on..
                            Thank you πŸ˜„
                              sigasiempre
                              Was this issue solved? My issue is similar. Movements and cameras I put in disappear when I re-open the file?
                                jonorman
                                Nope, not yet... Current conclusion is my computer is "Haunted" and filled with Gremlins.. Ha ha ha ha ha πŸ˜„
                                • I
                                  ignaciocarreras
                                  Hi Fredo! First of all thank you for this amazing plug in.
                                  And hi forum!
                                  I came back to a model I was working last night and there's nothing saved in the Animator-Clip Editor, but I think I probably didn't save it as I was very sleepy.
                                  So if the clip settings are not in the Clip Editor that means that I didn't save it?
                                  Or there is any way to find previous clips? Hopefully it's saved somewhere in a folder in my PC?
                                  Many thanks!
                                  • fredo6F
                                    All Animator information is saved within the model. So, if you retrieve a previous version or the last backup save (.skb), it should be there.
                                    This assumes however that you did save the animation at some point.
