    Explode groups
    7 Posts 3 Posters 1.9k Views 3 Watching
    • K
      koliboti
      Hi SketchUPers πŸ˜‰
      I am looking for a plugin that can explode groups inside groups.
      For example: I am want to expload all groups (A,B,C) inside groups X1,X2,X3,...
        Did you try searching the Plugin Store? TIG's Group Exploder would probably do what you need.
        • K
          koliboti
          Thank you Dave R! But this plugin explodes all the groups... and I want to explode only groups A,B,C and keep X1, X2, ...
          • TIGT
            To explode all groups found inside another group, but ignore those groups located in the model itself or inside components, you can use this one-liner copy+pasted in the Ruby Console + enter...
            m=Sketchup.active_model;m.start_operation('ex',true);m.definitions.find_all{|d|d.group?}.each{|g|next unless g.valid?;g.entities.grep(Sketchup;;Group).each{|e|e.explode}};m.commit_operation
            • K
              koliboti
              Woow TIG, it is working perfect! πŸ˜„ Thank You Very Much!
              It is hard to explode Components also?
              • TIGT
                No.
                If you want to ALSO explode components you could make this adjustment ??
                m=Sketchup.active_model;m.start_operation('ex',true);m.definitions.find_all{|d|d.group?}.each{|g|next unless g.valid?;(g.entities.grep(Sketchup;;Group)+(g.entities.grep(Sketchup;;ComponentInstance)).each{|e|e.explode}};m.commit_operation
                • K
                  koliboti
                  Thank You Very Much TIG! πŸ˜„
