    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 302.6k Views 17 Watching
      Hospices imaginaires ou ayant existés ?
      • mogrenM Offline
        mogren
        Décor film
        • halroachH Offline
          halroach
          @mogren said:
          What I would like ☀
          You should be able to get that with the following settings.
          'Inset' to move the window in/out in relation to the wall.
          'Frame - Depth' to get it as deep as you need.
          Play with the 'Frame - Width' setting to change what you wrote as Height in your picture.
          FlexTools - Super Quick Windows, Doors, Slats...
          • mogrenM Offline
            mogren
            @halroach said:
            @mogren said:
            What I would like ☀
            [attachment=1:3clrfqal]<!-- ia1 -->flexwindow arch in arch settings.png<!-- ia1 -->[/attachment:3clrfqal]
            To follow your example we need two windows one above the other to have the wooden frame (see the red arrow)?
              Je crois que oui, c'est ce qui était décrit dans les posts précédents 😉
              Il faut utiliser 2 composants l'un dans l'autre!
              I took two arch components, and placed one in the other.
              • mogrenM Offline
                mogren
                Oui effectivement pardon j'ai posé la question trop vite
                • mogrenM Offline
                  mogren
                  Ceci dit l'idéal n'est pas encore là
                    I can't load the Double Arch (Arch in arch) of the previous page ! It's not 2017 version! 😉
                    • halroachH Offline
                      halroach
                      Maybe this will work.
                      The outer is a wallcutter. The inner is marked with 'Exclude' in the wallcutter options window so it won't interfere with cutting an opening.
                      For the outer arch I deleted the glass, and did un-hide for the lines to get the stone appearance. A shortcut for doing this is to un-hide only for the left most 'stone'. Delete all the other stones and refresh. Then the left most stone copies it self all around.
                      The inner window is a regular arch window scaled to the right position.
                      The whole component as a whole won't scale together but you can always re-scale the inner component so it fits again.
                      You will then need to add the horizontal lines on the sides...
                      It's a quick solution for now. We'll see if we can make something like this in future updates...
                      Please add/vote for this idea at https://flextools.cc/idea-push - There is a similar idea there which actually sparked the creation of the arch window! 😎
                      [updated skp to 2017]
                      Arch in Arch.skp
                      • halroachH Offline
                        halroach
                        Updated to 2017!
                          Many Thanks! 👍
                          • halroachH Offline
                            halroach
                            New Flex Bifold component released!
                            Learn more at https://flextools.cc/blog/flex-bifold/
                            https://flextools.cc/wp-content/uploads/2020/06/bifold_01_02e.gif
                            • jujuJ Offline
                              juju
                              Thanks for the info, seems like I'm up to date already. Also checked after the e-mail the other day, same thing, already up to date.
                              • halroachH Offline
                                halroach
                                Hello everyone, we're glad to introduce a new 3 Sash FlexSlider.
                                A Multi Sash FlexSlider is also in development, but till it's ready, if you need a quick 3 sash sliding window/door this component will do the work. It works just like the original 2 sash FlexSlider.
                                https://flextools.cc/wp-content/uploads/2020/07/Three-Sash-Slider_01.gif
                                • halroachH Offline
                                  halroach
                                  We'd like to thank Alex Oliver from SketchUp School for including FlexTools in the list of 10 extension every architect should know.
                                  Check out all 10 extensions in the video: https://youtu.be/mtpEmbteWW8
                                  • halroachH Offline
                                    halroach
                                    New update for ComponentFinder!
                                    A new navigation sidebar, custom component toolbars, a better user interface and a lot more improvements!
                                    More info at the blog: https://flextools.cc/blog/new-componentfinder-navigation-bar-and-toolbars/
                                    If you find this update useful (or not!?) we want to hear you!
                                    • halroachH Offline
                                      halroach
                                      New Flex Multi Slider released! 🎉
                                      With any number of leaves you wish, 3 configurations, glass or solid panels - It will cover most of the sliding doors and windows you use day-to-day.
                                      Check it out: https://flextools.cc/blog/new-flex-multi-slider/
                                      https://flextools.cc/wp-content/uploads/2020/11/multi-slider_03_02-1000e.gif
                                      • halroachH Offline
                                        halroach
                                        We haven't done any promotions for a whole year, but hey, today is Black Friday! 😄
                                        ➡ https://flextools.cc/black-friday/
                                        • halroachH Offline
                                          halroach
                                          Thanks to Justin for the video!
                                          • halroachH Offline
                                            halroach
                                            Have you ever wished you could change default thumbnails with your own, see your rendered images instead of V-ray proxies? You can do that in ComponentFinder now!
                                            Assign your own thumbnails with custom images:
                                            Right Click > Set Custom Thumbnail > Choose a JPG or PNG
                                            The thumbnail image you assign will be automatically copied into the folder where the component is stored, and it will be named with the same name.
                                            Would you find custom thumbnails useful?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 7 / 9
