    Fredo6 plugins and High-Resolution / Retina screens
    18 Posts 8 Posters 10.4k Views 8 Watching
    • fredo6F Offline
      fredo6
      I am trying to address the problem, as I don't think Sketchup will do it anytime soon.
      I don't have a high-resolution screen myself, so I can only do simulation on my small screen.
      In principle, I have done a set of generic changes in LibFredo6 v7.7 that should address the button palettes and other visual elements. Then I'll probably have to go through individual plugins to make other adjustments.
      The support of high-Resolution screens should be as follows:
      1. Sketchup version < 16: No real support. The only thing possible is to enlarge the button palettes, but not the characters (since not supported by the Sketchup Ruby API)
      2. Sketchup 2016: you'll have to specify the scaling factor of the resolution (usually 2)
      3. Sketchup >= 2017: This should be automatic
      At this stage, I would like to hear from users about the issues encountered, in particular, whether the line thickness of visual elements drawn in the viewport are visible enough or should be thickened. For instance, in RoundCorner, I am talking about the green and red lines used to highlight selected edges.
      Please use this thread to report all issues.
      Thanks to all
      Fredo
      • pbacotP Offline
        Thanks for addressing this! Yes I think the indicator lines in the drawing area could be a little thicker, though they are already better than SketchUp highlights.
        • fredo6F Offline
          fredo6
          Thanks. Could you tell me what is your screen resolution. If you have Sketchup 2017, just type UI.scale_factor in the Ruby console.
          Fredo
          • fredo6F Offline
            fredo6
            By the way, anyone with a Hi-res screen who could test the new LibFredo6 v7.7?
            Fredo
            • pbacotP Offline
              Is the LibFredo6 v7.7 available on Sketchucation Plugin? Is it compatible with v. 2016?
                The briefest search of the PluginStore... https://sketchucation.com/pluginstore?pln=LibFredo6
                I'd expect some backwards compatibility - but you alone can test it 😉
                Read the text in the recent post https://sketchucation.com/forums/viewtopic.php?p=622575#p622575
                • fredo6F Offline
                  fredo6
                  V7.7 has been published.
                  In Su2016, you have to go to the LibFredo6 Default Parameters and
                  • Check "Enable High-res screen support"
                  • Enter the scale factor of your screen (say 2)
                  The 3rd parameter deals with the thickness of lines drawn in the viewport. By default they are thickened in hi-res. But if this is too much, just disable this option.
                  Fredo
                  • fredo6F Offline
                    fredo6
                    Strange. Apparently nobody reported that the support of hi-res screens with LibFredo6 7.7 does work or does not work!
                    Fredo
                    • P Offline
                      peerman
                      Hi Fredo, I think a lot of people are on holiday 😄 Anyway I just saw your post and tried it out on my 5k iMac. It works perfectly!
                      Thank you!
                      Best,
                      Peter
                      iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
                      • fredo6F Offline
                        fredo6
                        Thank you!
                        Best,
                        Peter
                        Peter,
                        Thank you for this feedback.
                        One question I have is about the thickness of lines drawn in the viewport (red and green for RoundCorner). On hi-res screen, I also increase the width of these lines (there is a flag in Default Parameters to disable the feature). Is it necessary?
                        Freo
                        • N Offline
                          nickchun
                          I do not have a high resolution screen however I am getting a frequent bugsplat with Thru Paint which I don't know if is related to this issue, but has only started happening a couple of weeks ago. When I activate the Thru Paint tool, the tool tip briefly changes to the SU native bucket tool then SU crashes. I have tested it on my start up template which has very few materials in it. The tool tip still changes briefly to the bucket but does not crash, it only crashes with models that have a lot more textures. I have tried activating the tool by shortcut keys, the toolbar and the Fredo tools menu and it happens with all of them....?
                          • fredo6F Offline
                            fredo6
                            This is not related at all to the question of hi-res screen.
                            Actually, I detected myself this bugsplat situation long time ago, and was surprised that no user did signal it.
                            In the latest version of FredoTools, I have made some changes and no longer have the bugsplat. But since this is a random problem coming from the timing between observers, it may happen or not depending on the environment.
                            So, do you have the problem with the latest FredoTools?
                            Fredo
                            PS: the issue with Thrupaint is that when you open the paint bucket dialog box, Sketchup automatically switches to the native Paint tool. So in ThruPaint, I have to switch back to ThruPaint tool. The problem is in the switching and tool observer.
                            • N Offline
                              nickchun
                              I thought I had the latest version but it was the Libaray I had updated. Just updated Fredo Tools and it all seems to work well again now.
                              Thank you very much, very useful tool.
                              • N Offline
                                nickchun
                                Unfortunately the problem is still occurring, even after the update...
                                • P Offline
                                  petrusca
                                  hey fríen. despite i followed all steps tu install curvizard I can not see any fredo6 option in de windows menu in stketch, It seems that is not istalled…. i received the installation confirmations.so may some one help ?
                                    Did you also install the current version of LibFredo6?
                                      Councilship
                                      Can anyone help with this error message?
                                      undefined method `vertices' for #Sketchup::OptionsProvider:0x00007fc9ab9b8378
                                      I'm doing a joint push pull in sketchup pro 2019 from a google earth contour map in show terrain mode
                                        Can you share .skp file so we can see what you've got?
                                        How did you get a Google Earth terrain map into SketchUp?
