    Vintage table lamp
    24 Posts 17 Posters 4.8k Views 17 Watching
    • massimoM Offline
      massimo Moderator
      This has been in my computer for quite a long time now. It was modeled starting from the real thing. I decided to try a couple of shots after a pretty quick set-up.
      Sketchup + Thea + a slight touch of pp with Arionfx.
      • Bryan KB Offline
        Gorgeous. Everything about it is gorgeouss. The camera, the texture, the light, the model. ๐Ÿ‘
        • ntxdaveN Offline
          ntxdave
          +1
          Press F1...thank me later
          • tuna1957T Offline
            tuna1957
            absolutely stunning. ๐Ÿ‘ ๐Ÿ‘
            • massimoM Offline
              massimo Moderator
              Thanks for the kind words guys. ๐Ÿ˜„
              • pbacotP Offline
                beautiful! Realism is stunning, setup is professional! and I wish I could get a lamp like that.
                • StinkieS Offline
                  Stinkie
                  Not bad. ๐Ÿ’š
                  Good-looking shaders. ๐Ÿ‘
                    Absolutely brilliant.
                    • HornOxxH Offline
                      HornOxx
                      ... just perfect! love it ! ๐Ÿ‘
                      never trust a skinny cook
                      • massimoM Offline
                        massimo Moderator
                        Thanks everybody once again. ๐Ÿ˜„
                        • cheddaC Offline
                          chedda
                          Excellent.
                          Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                          • cottyC Offline
                            cotty
                            The background is an EXR or modeled too? Nice texturing!
                            my SketchUp gallery
                            • alvisA Offline
                              alvis
                              Nice!
                              • massimoM Offline
                                massimo Moderator
                                Thanks guys. ๐Ÿ˜„
                                The background is simply a HDRI. You can find it in the sIBL archive, it's called "van Kleef 3".
                                  Lavanta
                                  Great work! Looks very real! Was it difficult for you to do this? It looks really time-consuming.
                                  • massimoM Offline
                                    massimo Moderator
                                    Thanks.
                                    No, neither difficult nor time consuming. As I said it was a quick set-up. ๐Ÿ˜‰
                                      Lavanta
                                      @massimo said:
                                      Thanks.
                                      That's awesome. Looks can be deceiving, I guess ๐Ÿ˜› I could've sworn this was extremely difficult to make, but I like getting surprised ๐Ÿ’š
                                      • DanielD Offline
                                        Daniel
                                        Perfection
                                        This deserves to be in the most impressive thread.
                                        My avatar is an anachronism.
                                        • david_hD Offline
                                          david_h
                                          terrific. I have really struggled. . .well. . .kinda. . .but not really. . .trying to model and rendering a light bulb like that? ๐Ÿ˜ฎ
                                          Share the recipe?
                                          • massimoM Offline
                                            massimo Moderator
                                            Well thanks for the very kind words guys.
                                            @david_h said:
                                            ...trying to model and rendering a light bulb like that? Share the recipe?
                                            The original model of the bulb is on warehouse if I recall well, but I've made some tweaks like, for example, giving thickness to the filament. As you can see also the bulb has thickness.
                                            Here you have some ss of the model and the material applied to the filament.
                                            The bulb has a standard thin film glass material on it.
                                            Of course there is a bit of radial glare in the final image (something like weight = 30% and radius = 4%) coming directly from Thea's darkroom.
                                            Hope this helps a bit. ๐Ÿ˜„
                                            • 1 / 2
