    Vray 3.4 Indirect Ilumination - Saturation
    renderpluginsextensions
    6 Posts 5 Posters 4.0k Views 5 Watching
    • D
      dss702
      Hi everybody! Just wondering where the Post-Processing menu under Indirect Ilumination went on thus new version. The Saturation option is missing. Does anyone have a clue?
      Thanks for the help in advance.
      • Collage ArchitectureC
        You can tweak saturation in V-Ray Frame Buffer
        I love Sketchup
        • D
          dss702
          Actually I was more concerned about the color bleeding. The Saturation option under Indirect ilumination was able to reduce the color bleed without affecting materials saturation. I did some tests renders and noticed that the color bleeding issue is not so intense on this new version.
          • V
            valerostudio
            I think that it was probably improved because the bleed was inaccurate.
            • troyhomeT
              troyhome
              I was looking for it too... accurate or not, I want control over it. I'm getting a ton of bleed from the skydome and some grass outside all reflecting into the interior.
              IOviz.com
              SU Pro 2024 PC
              • frankflafyF
                frankflafy
                me the same. still searching for saturation option in vray 3. color bleed is everywhere when i dont have the option.
                ps: i dont want to edit the option in material option. its to much.
