    Help building a continuous geometry
    5 Posts 4 Posters 495 Views 4 Watching
      r9rqjckh
      hello all, i am struggling to build a certain kind of a model.
      the idea is to build a surface of repetitive lines following this design:
      https://s30.postimg.org/q02yq7jfl/Screen_Shot_2017_03_02_at_14_46_27.png
      resim yüke
      because there is a continuous series of lines (and there will be several more models like this) i am trying to find a formula of automatically drawing these lines, rather than drawing manually myself. so what needs to be drawn on sketchup is like this: (this is what i drew manually to explain you the idea)
      https://s9.postimg.org/b05qeyyn3/Screen_Shot_2017_03_02_at_14_50_04.png
      hızlı resim yükle
      and the challenge also is, each combination of vertical lines, needs to be a component so that i can give thickness and create some kind of fence out of them.
      each element will eventually need to be something like this:
      https://s13.postimg.org/xrsvav36v/Screen_Shot_2017_03_02_at_14_56_23.png
      ücretsiz resim barındırma
      i wonder what would be a smart way to model this. hope someone can help...
        Only thing I can think of is ThomThom Connect Edges in QFT extension.
          r9rqjckh
          @rich o brien said:
          [attachment=0:z8ucthdp]<!-- ia0 -->screen-grab_125.jpg<!-- ia0 -->[/attachment:z8ucthdp]
          Hi Rich, thanks for your message. i also can see that this might help. i dont know how to access the extension you mean. is it "Edge Tools2" or "QuadFace Tools" by @thomthom . or sth else? can you please let me know how i access the extension you mention.
          • filibisF Offline
            filibis
            It is QuadFace Tools by ThomThom as Rich mentioned. Here is the link for it: https://extensions.sketchup.com/en/content/quadface-tools
              You have also Split tools by TIG ! 😉
              Lines must be divided before! 🤓
