    Version 2 is out!
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    69 Posts 16 Posters 45.6k Views 16 Watching
      Now powered by OpenSubdiv
      Check out full changelog here: http://evilsoftwareempire.com/subd/changelog/2.0
      Oh - and by the way, there is currently a 50% discount of SUbD and Vertex Tools!
        Hooray!
        • O Offline
          optimaforever
          Gr8!!!
          Do we have to unistall v1 first or...?
            @optimaforever said:
            Gr8!!!
            It should replace it. Should you find any problems - uninstall and install fresh. (And report back off course ๐Ÿ˜‰ )
            • JQLJ Offline
              JQL
              I wished I had time to play with this one. It's looking really great! Congratulations TT!
              www.casca.pt
              Visit us on facebook!
              • O Offline
                optimaforever
                Gr8!!!
                Indeed, it replaced the v1 perfectly so far.
                Thanks! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                • cottyC Offline
                  cotty
                  ๐Ÿ˜„ ๐Ÿ‘
                  my SketchUp gallery
                  • ithilI Offline
                    ithil
                    Wow! Great news!
                    I'm really happy. Many thanks for your work
                    • O Offline
                      optimaforever
                      Is QFT your next release target?
                        It will probably be Vertex Tools 2.
                          Damned: i must update my French SubD Mirror site! โ˜€
                            Done! ๐Ÿ˜‰
                            (publicity also) ๐Ÿ˜„
                              So...You are on Top Raw on the biggest French 3D Site! ๐Ÿ˜‰
                              http://www.3dvf.com/actualite-19384-subd-2-0-opensubdiv-arrive-sous-sketchup.html
                              And in the news of CGTtalk! ๐Ÿ˜‰
                              etc...
                                ๐Ÿ˜„
                                • alvisA Offline
                                  alvis
                                  finally! Thanks
                                  • OxerO Offline
                                    Oxer
                                    I installed the v2.0 on OS X 10.11.6 & SU2017, the first run of the plugin all ok, but when I close the Entity Info window and I reopen it, the window shows --> "Nothing Selected" and I have a selected group.
                                    Other times, if you have 2 entities with different SUbD applied and you change between them, the Entity Info window doesn't refresh the info. The Ruby Console is empty.
                                    The Entity Info window doesn't show all buttons, I have to resize it manually because there isn't scrollbar.
                                    http://www.oxervision.blogspot.com/
                                      Hm.. I will have to look into that. Might be that I'm not handling observers right for OSX multiple window interface.
                                      Logged issue as #266
                                      • OxerO Offline
                                        Oxer
                                        If you want that I test some feature especially, tell me it. Except the Entity Info, the rest of the icons work fine.
                                        The Display Edges hides all edges in the model, not only the edges with SUbD applied, is this normal or is it a issue?
                                          That was the v1 feature. In v2 you have options to control this locally for the mesh.
                                            Hello
                                            Curious aspect of the icons! ๐Ÿ˜ฎ
                                            Edit : Problem Solved! That was direct download first time! ๐Ÿค“
                                            I relaunch Su and now seems cool ! ๐Ÿ˜Ž
                                            Just a little thing : no Number of Version on title ?
                                            • 1 / 4
