    Can you save to SketchUP 7 as default
    7 Posts 4 Posters 1.5k Views 4 Watching
    • P
      PRSS
      Hello
      May be this is a dumb question.
      Is there any way of always save skp files to SketchUP 7 ?
      Autocad has a default saveas mode in options so that one could always make it as a default.
      But I could not find any such options in SketchUP 2017 Pro.
      I have just purchased SketchUP 2017 Pro 2 copies and installed. I still have 2 old computers (in very good condition) running Google SketchUP 7 in Windows XP in my 4 man army office(including me)
      If I could make it as default to always save as skp 7 version, it would be convenient to move files between the new & old computers. (of course it could be done manually but it does take an extra effort).
      Thanks in advance
      PRSS
      • TIGT
        You can of course use File>Save_As to save your v2017 model to many much earlier versions.
        However, there are some plugins to add an automatic File>Save_As_... option to the menu, which you could then make a shortcut-key to use...
        I think Jim Foltz wrote one ??
        • S
          slbaumgartner
          The Ruby API has support for the required operation, so if you can't find one it would be very easy to write a plugin that creates a toolbar button or menu item that saves to (e.g.) SU version 7. The key statement, paraphrased directly from the API docs, is just:
          status = Sketchup.active_model.save("", Sketchup::Model::VERSION_7)
          • P
            PRSS
            I thank both of you for the replies. I have not written any ruby so far but I shall try to create what you wrote.
            Best regards
            PRSS
            • P
              PRSS
              Hello slbaumgartner
              Your script worked when I copy pasted it in the console. But you were mentioning about a button that could run this script. I have no idea of scripting & the like and I might never learn it too. Can you please tell me how to make a button for just this script?
              I could not get Jim Foltz's script for this however much I Googled for it. I could not find it in his Web site's my plugins" too.
              Any help would be greatly appreciated.
              Thanks in advance
              PRSS
              • C
                Charlie__V
                @prss said:
                Hello slbaumgartner
                Thanks in advance
                PRSS
                This may be the one TIG was referring to. (by Jim)
                http://sketchucation.com/forums/viewtopic.php?t=33441
                • P
                  PRSS
                  Thanks a ton Charlie !
                  This is working fine for me.
                  Best regards
                  PRSS
