    SU 2015 Pro "send to layout is grayed out"
    38 Posts 6 Posters 4.3k Views 6 Watching
      mwm5053
      I got a new IMac with 10.12.2 Sierra and installed SU Pro 2015 (license activated) and when I went to send a file to LO after I saved it in SU "send to LO was grayed out". I searched the Web for an answer and found this thread on the SU forum
      https://forums.sketchup.com/t/send-to-layout-not-working-help-please/16789
      Nothing in the thread applied to my circumstance. The app names (SU, LO )were not moved or renamed. I opened the SU file in LO and everything was good and the Document Setup/ Ref was current. But "send to LO out is still grayed out".
      I'm at a loss.
      Walt
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        Hi Walt,
        Does SketchUp show that your pro license is activated? Can you open LayOut directly?
          mwm5053
          Yes I can open LO either directly or with an old LO fie.
          2011 iMac
          V2 Twilight
            Did you try reinstalling SketchUp? I have vague recollections of someone else having this problem and reinstalling being the solution.
              mwm5053
              I'll do that and get back at you.
              2011 iMac
              V2 Twilight
                Good luck.
                  mwm5053
                  Nope didn't work. Wonder if I need to uninstall first. I read some where to uninstall SU you needed to delete the plist also.
                  2011 iMac
                  V2 Twilight
                    Maybe just deleting the plist would work. If it is corrupt, that could cause problems. SketchUp would rewrite the plist next time you start up. We need a Mac guru in here.
                      Somebody called?
                      http://static4.businessinsider.com/image/50ec9336ecad04e86c000001-506-253/mcdonalds-will-relaunch-the-big-mac-this-year-with-a-blast-of-new-ads.jpg
                        It's about time! 😄
                          mwm5053
                          Well I'm bewildered (nothing new there) SU dmg reinstalled and asked to replace old and I chose yes. Restarted Mac and opened SU and LO all works fine, even with the file or any other file they don't seem to be linked. Even making changes to SU file doesn't show in Document Setup in LO and they're both open.
                          2011 iMac
                          V2 Twilight
                            mwm5053
                            So Rich "What say ye"
                            2011 iMac
                            V2 Twilight
                              Only thing that comes to mind is file format.
                              Are you trying to send a 2017 file to LayOut 2016 or something along those lines.
                              Or maybe some legacy issue to when LayOut was not suffixed with the year.
                              I tried it on the Mac we have and can't see a problem.
                                I wouldn't have a clue how to fix it. Sorry.
                                Maybe your Reseller can help expedite the issue?
                                  mwm5053
                                  Must be the second because the first is not the case.
                                  Could it be something with 2017 Make overriding something? Wouldn't think so.
                                  2011 iMac
                                  V2 Twilight
                                    Do you have 2017 Make installed? If so, that would be a problem because LayOut isn't available for Make.
                                      He edited his post to say Make is installed.
                                      Try nuking it.
                                        mwm5053
                                        Yeah. but these are SU 2015 files being opened in SU 2015 and using LO 2015
                                        2011 iMac
                                        V2 Twilight
                                          mwm5053
                                          @ Rich think I'll do that.
                                          2011 iMac
                                          V2 Twilight
                                            I think I see what you've got going on. You can't send files from SU2017 to LO2015. You would have to save from SU2017 back to SU2015. You could then send the file from SU2015 to Lo2015.
                                            • 1 / 2
