    SU 2015 Pro "send to layout is grayed out"
    38 Posts 6 Posters 7.1k Views 6 Watching
      mwm5053
      Nope didn't work. Wonder if I need to uninstall first. I read some where to uninstall SU you needed to delete the plist also.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        Maybe just deleting the plist would work. If it is corrupt, that could cause problems. SketchUp would rewrite the plist next time you start up. We need a Mac guru in here.
          Somebody called?
          http://static4.businessinsider.com/image/50ec9336ecad04e86c000001-506-253/mcdonalds-will-relaunch-the-big-mac-this-year-with-a-blast-of-new-ads.jpg
            It's about time! 😄
              mwm5053
              Well I'm bewildered (nothing new there) SU dmg reinstalled and asked to replace old and I chose yes. Restarted Mac and opened SU and LO all works fine, even with the file or any other file they don't seem to be linked. Even making changes to SU file doesn't show in Document Setup in LO and they're both open.
              2011 iMac
              V2 Twilight
                mwm5053
                So Rich "What say ye"
                2011 iMac
                V2 Twilight
                  Only thing that comes to mind is file format.
                  Are you trying to send a 2017 file to LayOut 2016 or something along those lines.
                  Or maybe some legacy issue to when LayOut was not suffixed with the year.
                  I tried it on the Mac we have and can't see a problem.
                    I wouldn't have a clue how to fix it. Sorry.
                    Maybe your Reseller can help expedite the issue?
                      mwm5053
                      Must be the second because the first is not the case.
                      Could it be something with 2017 Make overriding something? Wouldn't think so.
                      2011 iMac
                      V2 Twilight
                        Do you have 2017 Make installed? If so, that would be a problem because LayOut isn't available for Make.
                          He edited his post to say Make is installed.
                          Try nuking it.
                            mwm5053
                            Yeah. but these are SU 2015 files being opened in SU 2015 and using LO 2015
                            2011 iMac
                            V2 Twilight
                              mwm5053
                              @ Rich think I'll do that.
                              2011 iMac
                              V2 Twilight
                                I think I see what you've got going on. You can't send files from SU2017 to LO2015. You would have to save from SU2017 back to SU2015. You could then send the file from SU2015 to Lo2015.
                                  mwm5053
                                  No sorry SU 2017 doesn't have anything with what I'm doing It's all 2015.
                                  That being said I uninstalled both 2017 Make and 2015 Pro. The folders in Applications folder ,
                                  also the / Library /Application Support /folders for both 2015 and 2017 and the plist in the /Library/Applications Support/Preferences list like SU says on their website. Reinstalled SU 2015 and activated Lic. and "send to Layout is still greyed out".
                                  2011 iMac
                                  V2 Twilight
                                    Walt, I woke up thinking about your issue and it occurred to me that you are running SU/LO 2015 on Sierra. SU/LO 2015 isn't compatible with Sierra. I wonder if that has something to do with the problem.
                                      mwm5053
                                      Yes @ Dave, as it turns out as I expected it's a compatibility issue. Sketchup has dropped support of 2015 in later Mac OSX
                                      https://help.sketchup.com/en/article/36208
                                      2011 iMac
                                      V2 Twilight
                                        I wouldn't say they dropped support. They don't do further development of older versions after a newer version is released. They never have done so. SU2015 wasn't developed for Sierra because Sierra came well after SU2015.
                                        Are you going to update to SU2017?
                                          mwm5053
                                          Well, I'd like to keep up to date and I will use 2017 Make, but purchasing a upgrade Lic really is not a priority these days.
                                          So I think if I come across some paid work that I would need to use SU to LO feature I would probably go back to a supported OS X
                                          2011 iMac
                                          V2 Twilight
                                            mwm5053
                                            I did some house plans for a local contractor last year so he could get a building permit.
                                            I was glad to see my somewhat expertise in SU would actually payoff but he ended up moving his business out of state so you never know what might come up.
                                            2011 iMac
                                            V2 Twilight
