    [Tutorial] Animator Quick Start
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    136 Posts 39 Posters 761.9k Views 40 Watching
    • ArchiblogA Offline
      Archiblog
      Hi mgfranz!
      You might like to take a look at a tutorial by Justin Geis which shows you how to create an exploded view animation using Animator. Around about the 5:30 mark, Justin shows you how to reverse the explosion so that might give you some idea of how to achieve the effect you want.
      The tutorial can be found at:
      Let us know how you get on.
      NF
        mgfranz
        @archiblog said:
        Hi mgfranz!
        NF
        Thanks NF, but I don't think using the explosion will work in this instance since I have the need to place a total of 12 screws in 3 different locations. I suppose I could do some Easing on the fly-in group, let me do some research. I have attached my SU and animation file for a visual reference, just remove the .txt extension.
        13x3 Exploded_Anim.skp
        13x3 Exploded_Anim.animator.txt
        "If you like what you do, it will never be work..."
        In memory of Sam Maloof, 1916-2009
          mgfranz
          Ok, it took a while, but I got it figured out. I had to create a variety of transitions, once I placed the objects in the correct location I backed out the object to a location off-scene, then just reversed the movements.
          1. Fixed the screws in place
          2. Backed them off
          3. Moved them off scene
          4. Created transition to move them back
          5. Created transition to move them again
          6. And again.
          Not real pretty, but it works. Still may play with some linear motions, but I got it solved. Not sure why the graphics are pixilated, .avi sucks, .mp4 is fine. I'll play with FPS.
          Film 1.avi
          • jgbJ Offline
            jgb
            Looked OK to me. You did what I was going to suggest, but didn't as I got sidetracked out (wife!) as I was going to reply.
            jgb
            • fredo6F Offline
              fredo6
              It's in my plan to address these types of movement, with a Move-to tool (also to be used to align objects in bulk).
              Fredo
                snapkin
                Hey, thanks for this excellent plugin.
                I got a problem with that ffmpeg I download it and it works.
                but when I get in to do Extension i push the find the ffmpeg nothing happens.
                maybe you know how to fix it?
                • fredo6F Offline
                  fredo6
                  This is a bug which I fixed in LibFredo6 8.4g, just released.
                  Fredo
                  • soloS Offline
                    solo
                    I need some help, I cannot seem to be able to get multiple objects to follow a path properly, anyone know how to achieve this?
                    http://www.solos-art.com
                    • ntxdaveN Offline
                      ntxdave
                      [attachment=0:14vt9cpa]<!-- ia0 -->rotation.JPG<!-- ia0 -->[/attachment:14vt9cpa]
                      If they do not need to move indepently, how would it be to group them?
                      Press F1...thank me later
                      • fredo6F Offline
                        fredo6
                        The Follow Path tool (like other tools) allows to select several objects (keep CTRL depressed).
                        Fredo
                          cgalaon
                          I've got the same problem in Sketchup 2018 😞
                          I copied the ffmpeg.exe and executed it in the directory C:\Users(User Name)\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp\Plugins and in the directory: C:\Users(User Name)\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp\Plugins\Fredo6_!LibFredo6
                          WITH NO AVAIL!!!
                          Any help, please?!
                          This is the error from Ruby console:
                          Error: #<Errno::ENOENT: No such file or directory @ dir_s_mkdir - C:/Users/Chip/Desktop/TPOS/Animator Videos/Pressure gauge - 21-Sep-2018 09-57-10 - Gauge 3/4>
                          c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:921:in mkdir' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:921:in movie_create_folder'
                          c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:831:in movie_top_generate' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatortool.rbe:2204:in movie_dialog_call_back'
                          c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:381:in call' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:381:in notify_result'
                          c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:449:in on_close' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:412:in block in dialog_create'
                          c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:583:in call' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:583:in j_onclose'
                          c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:293:in block in create_dialog' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:322:in call'
                          c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:322:in close' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:322:in close'
                          c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:460:in close_validate' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:1251:in param_dialog_callback'
                          c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:752:in call' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:752:in j_action'
                          c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:634:in j_callback' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:622:in block in j_dispatch'
                          • fredo6F Offline
                            fredo6
                            Is "Pressure gauge - 21-Sep-2018 09-57-10 - Gauge 3/4" the name of your file? If so, then 3/4 is probably creating an issue, as '/' is used as a folder separator.
                            Fredo
                              cgalaon
                              @migmat said:
                              PROBLEM GENERATING VIDEO with ffmpg.exe INSKETCHUP 2013 (Works Animator for this versión?)
                              1- Animator Beta Works OK
                              2- Install ffmpeg.exe in LibFredo6 (disapear the red text to Find the ffmpeg.exe)
                              3- Make a simple animation that Works fine in preview
                              4- Try to generate a video with defaut parameters. Push the button "Test Image" and also work
                              5- Push the button "Generate Video" and NOTHING HAPPENDS. Sketchup continues inside the animator plugin. I can exit and star again the plugin,but nothing happends.
                              I instal the two versión of ffmpeg.exe, the last and the 3.2 (more stable).
                              Thanks in advance
                              PROBLEM SOLVED!!!!
                              M8, I had the same problem until I figured it out. When you name your "Film" in Animator, DON'T USE symbols like the followings (the ones that Windows files creator wouldn't allow it either): \ / : * ? " <> and |. Change the name using other symbols (all the rest, the allowed ones) and TACHA!!
                              Regards to all readers and SU/Animator users. Chip
                                CiscoNA
                                I can not find the button of the Animator plugin in Sketchup 2018. Is it visible in my extension manager but I can not open the plugin. What do i need to do?
                                • fredo6F Offline
                                  fredo6
                                  Did you install the companion library LibFredo6?
                                    Auressalmi
                                    Hi!
                                    I did a quick animation and tried to make it mp4-video, but it fails every time?
                                    Animation runs fine on Sketchup and video render does open and work, but when its done
                                    MP4- button is red and says "error in the video file generation".
                                    I have tried different setting and FFmpeg.
                                    I have Windows 7, Animator 2.3c and sketchup 2017
                                    Greetings from Finland - Juho
                                    • fredo6F Offline
                                      fredo6
                                      Juho,
                                      I would need that you post or PM the model to me to investigate.
                                      Fredo
                                        Auressalmi
                                        Thanks for quick answer!
                                        Here is the file, do you need something else?
                                        Edit Tested on different model, same error message.
                                        -Juho
                                        Hammastanko_Sähköohjaustehostin.skp
                                        • fredo6F Offline
                                          fredo6
                                          Strange. I can generate the movie in Natural mode (i.e. without rendering).
                                          Are you trying with a rendering software ?
                                          Film 1.mov
                                            Auressalmi
                                            I have followed instruction from the page 1. and i'm using all the same software's ect.
                                            I don't fully understand what you mean with rendering software, but i'm using Animator only, nothing else.
                                            I have tried different things here and there with no success.
                                            -Juho
                                            • 6
                                            • 7
                                            • 4 / 7
