    [Tutorial] Animator Quick Start
    renderpluginsextensions
    136 Posts 39 Posters 893.2k Views 40 Watching
      applemango85
      Could I ask a question?
      Love the plugin fredo - looks harder to use than it actually was so that was good news
      I'm making a few 60sec videos to show my boss a new way of presenting work. My settings was set at 20fps and speed of 0.75.
      However when playing the mov/MP4 file created I get a stutter every second or 2 - making it a bit unwatchable.
      Anyone come by the same problem?
      I can't post the video on the forum but I can private message it to anyone who think they can help.
      I'm trying one now at 45fps - seeing if that makes a difference
      There is a option to use QuickTime screen record to record a window once I've made the animater plugin film which will take a lot much less time to process but will take up much more mb- so perhaps not a solution
      • fredo6F
        Difficult to say without seeing the model and animation.
        You can PM it to me and I'll have a look.
          applemango85
          I redone 2 of my 3 animations in 45fps which seems to have solved the smoothness issue touch wood.
          The 3rd animation is being redone now so I should know for sure soon
          Is it normal for a 2min 45fps animation to take 3-5 hrs to process into video format?
          Fortunately I have both a laptop and desktop mac- and both pretty powerful so the time it’s taking seems excessive
          • fredo6F
            Good remark.
            The only way to capture the viewport in Ruby is a method (view.write_image), which may take from 0.1s to 3-4 second to get the viewport and put it in a PNG file, depending on:
            • the size of your viewport resolution
            • the complexity of the model
            I would propose that you execute the following one-line command in your Ruby console
            t0 = Time.now ; Sketchup.active_model.active_view.write_image("C:/toto.png") ; puts "Time = #{Time.now-t0}s"
            This will give you the minimum time to generate a single frame.
            You can also get the resolution of the viewport by typing the two commands
            Sketchup.active_model.active_view.vpwidth
            and
            Sketchup.active_model.active_view.vpheight
            NOTE: From the parameters you give, 2 minute video at 45 fps, so 5,400 frames, if it takes 4 hours, then each frame takes 2.6 second in average to be generated.
              mgfranz
              Great Animator Fredo! Once I got my system issues fixed I was able to create my animation in less than 10 min after watching the tutorials. So now I want to try something, is it possible for a object or group to "fly-in" from off scene? Like if I want to have screws installed in a component at a certain time point? For example, in the first 4 seconds of my animation, a group is moved into another component, at this point, I want a group of screws to come flying in from off scene and then place themselves in the clip at 5 seconds, do their thing, then finish the clip as normal. Possible?
              "If you like what you do, it will never be work..."
              In memory of Sam Maloof, 1916-2009
              • ArchiblogA
                Archiblog
                Hi mgfranz!
                You might like to take a look at a tutorial by Justin Geis which shows you how to create an exploded view animation using Animator. Around about the 5:30 mark, Justin shows you how to reverse the explosion so that might give you some idea of how to achieve the effect you want.
                The tutorial can be found at:
                Let us know how you get on.
                NF
                  mgfranz
                  @archiblog said:
                  Hi mgfranz!
                  NF
                  Thanks NF, but I don't think using the explosion will work in this instance since I have the need to place a total of 12 screws in 3 different locations. I suppose I could do some Easing on the fly-in group, let me do some research. I have attached my SU and animation file for a visual reference, just remove the .txt extension.
                  13x3 Exploded_Anim.skp
                  13x3 Exploded_Anim.animator.txt
                    mgfranz
                    Ok, it took a while, but I got it figured out. I had to create a variety of transitions, once I placed the objects in the correct location I backed out the object to a location off-scene, then just reversed the movements.
                    1. Fixed the screws in place
                    2. Backed them off
                    3. Moved them off scene
                    4. Created transition to move them back
                    5. Created transition to move them again
                    6. And again.
                    Not real pretty, but it works. Still may play with some linear motions, but I got it solved. Not sure why the graphics are pixilated, .avi sucks, .mp4 is fine. I'll play with FPS.
                    Film 1.avi
                    • jgbJ
                      jgb
                      Looked OK to me. You did what I was going to suggest, but didn't as I got sidetracked out (wife!) as I was going to reply.
                      jgb
                      • fredo6F
                        It's in my plan to address these types of movement, with a Move-to tool (also to be used to align objects in bulk).
                          snapkin
                          Hey, thanks for this excellent plugin.
                          I got a problem with that ffmpeg I download it and it works.
                          but when I get in to do Extension i push the find the ffmpeg nothing happens.
                          maybe you know how to fix it?
                          • fredo6F
                            This is a bug which I fixed in LibFredo6 8.4g, just released.
                            • soloS
                              I need some help, I cannot seem to be able to get multiple objects to follow a path properly, anyone know how to achieve this?
                              • ntxdaveN
                                ntxdave
                                [attachment=0:14vt9cpa]<!-- ia0 -->rotation.JPG<!-- ia0 -->[/attachment:14vt9cpa]
                                If they do not need to move indepently, how would it be to group them?
                                Press F1...thank me later
                                • fredo6F
                                  The Follow Path tool (like other tools) allows to select several objects (keep CTRL depressed).
                                  • C
                                    cgalaon
                                    I've got the same problem in Sketchup 2018 😞
                                    I copied the ffmpeg.exe and executed it in the directory C:\Users(User Name)\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp\Plugins and in the directory: C:\Users(User Name)\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp\Plugins\Fredo6_!LibFredo6
                                    WITH NO AVAIL!!!
                                    Any help, please?!
                                    This is the error from Ruby console:
                                    Error: #<Errno::ENOENT: No such file or directory @ dir_s_mkdir - C:/Users/Chip/Desktop/TPOS/Animator Videos/Pressure gauge - 21-Sep-2018 09-57-10 - Gauge 3/4>
                                    c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:921:in mkdir' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:921:in movie_create_folder'
                                    c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:831:in movie_top_generate' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatortool.rbe:2204:in movie_dialog_call_back'
                                    c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:381:in call' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:381:in notify_result'
                                    c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:449:in on_close' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:412:in block in dialog_create'
                                    c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:583:in call' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:583:in j_onclose'
                                    c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:293:in block in create_dialog' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:322:in call'
                                    c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:322:in close' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:322:in close'
                                    c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:460:in close_validate' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:1251:in param_dialog_callback'
                                    c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:752:in call' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:752:in j_action'
                                    c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:634:in j_callback' c:/users/chip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe:622:in block in j_dispatch'
                                    • fredo6F
                                      Is "Pressure gauge - 21-Sep-2018 09-57-10 - Gauge 3/4" the name of your file? If so, then 3/4 is probably creating an issue, as '/' is used as a folder separator.
                                      • C
                                        cgalaon
                                        @migmat said:
                                        PROBLEM GENERATING VIDEO with ffmpg.exe INSKETCHUP 2013 (Works Animator for this versión?)
                                        1- Animator Beta Works OK
                                        2- Install ffmpeg.exe in LibFredo6 (disapear the red text to Find the ffmpeg.exe)
                                        3- Make a simple animation that Works fine in preview
                                        4- Try to generate a video with defaut parameters. Push the button "Test Image" and also work
                                        5- Push the button "Generate Video" and NOTHING HAPPENDS. Sketchup continues inside the animator plugin. I can exit and star again the plugin,but nothing happends.
                                        I instal the two versión of ffmpeg.exe, the last and the 3.2 (more stable).
                                        Thanks in advance
                                        PROBLEM SOLVED!!!!
                                        M8, I had the same problem until I figured it out. When you name your "Film" in Animator, DON'T USE symbols like the followings (the ones that Windows files creator wouldn't allow it either): \ / : * ? " <> and |. Change the name using other symbols (all the rest, the allowed ones) and TACHA!!
                                        Regards to all readers and SU/Animator users. Chip
                                        • C
                                          CiscoNA
                                          I can not find the button of the Animator plugin in Sketchup 2018. Is it visible in my extension manager but I can not open the plugin. What do i need to do?
                                          • fredo6F
                                            Did you install the companion library LibFredo6?
                                            • 4 / 7
