    [Plugin] Animator - v4.6a - 18 Dec 25
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    602 Posts 120 Posters 2.3m Views 120 Watching
    • fredo6F
      fredo6
      What you describe is probably beyond the approach possible with Animator, VRay and Sketchup. if you need 120 frames (5 seconds at 24fps), each rendering in 30-40 minutes, then it is likely that either Animator, Sketchup or VRay will have problem.
      I don't have a solution at the moment, sorry. Generating 120 skp model files (or 120 scenes) is a possibility, but that does not give a satisfactory solution because it does not scale up. And this is not easy to implement anyway.
      • C
        Calcifer
        Hello Fredo,
        Thank you for your quick response. I was afraid it would be your answer. That been said I may find a convoluted way to work around the animator and SU limitations.
        I have a last question: if I would like to improve my hardware to use animator (just for opening animator and use it), should I focus more on CPU or GPU?
        Thanks!
        • fredo6F
          fredo6
          I personally do not know. This is anyway related to the rendering software not to Animator.
          So I would suggest you ask Chaos Group (or check their forum, where I am sure there would be plenty of good advice)
          • L
            Luke_123
            Hey Fredo,
            big thanks to you for the Animator software!
            I have a quick question: Animator smooths out the transition between two views - but if there is a third view there will be a sudden change in camera movement at the second view. Is there a way to smooth this out also?
            Thanks!
            • fredo6F
              fredo6
              You should not have 3 cameras active at the same time, only 2.
              • L
                Luke_123
                Do you mean I should not use more than two views in one video segment?
                Well, thats not gonna do it for a flythrough 😄. But then that is probably not what you had in mind for Animator. I had just hoped I could use it, as everything else I have tried hasnt't worked out for me so far 😕
                (MS Physics not installing, using native scenes to get an animation is jerky too, camera key maker is really hard to edit and, even though I found the video file in the temp folder, it was broken)
                • fredo6F
                  fredo6
                  You can have as many camera as you wish, but in sequence.
                  You can set each camera to fade out at the transition with the next one (orange underline of the camera object in the timeline).
                  What I say is that the interpolation is done between 2 cameras, not 3 cameras.
                  In your case, you probably need to set fade-out transitions.
                  The best would be that I see the model.
                  • ntxdaveN
                    ntxdave
                    Fredo, just curious if you have looked at integrating D5 Render with Animator?
                    Press F1...thank me later
                    • fredo6F
                      fredo6
                      New Release: Animator - v3.8a - 25 Dec 22
                      Requirement: LibFredo6 v13.6
                      Maintenance release
                      • Bug fixing
                      • Extension of validity
                      See plugin home page of Animator for Download of RBZ from the PluginStore.
                      See Main Post of the Animator thread for more information.
                      • A
                        ARS2Rust
                        WHEN I USE ANIMATOR WITH VRAY, I CANNOT GET IT TO USE MY EXTERNAL GPU. SINGLE FRAMES HIT THE eGPU BUT NOT THE ANIMATION FRAMES FROM ANIMATOR.
                        THOUGHTS?
                        PARK WARNE
                        • fredo6F
                          fredo6
                          THOUGHTS?
                          For the time being, Animator uses the direct API to VRay, which is not triggering GPU calculations.
                          • T
                            thalisongil
                            how to transform any frame from fredo animator plugin in a new scene inside sketchup? I’ve been create a animation with some frames using the fredoanimator. How can I to transform any frame from fredo animator in a new scene in my sketchup?
                            My objective: If i get to create these scenes, i'll to render with Enscape using the batch render,so.. If i create all these scene i can generate a "Property Brothers" effect. I gotcha this with the Keyframe Animator, but, this plugins doens't has a lot options like the fredo animator.
                            (sowwy for my grammar errors, i'm brazilian and i'm not fluency 😄 )
                            • fredo6F
                              fredo6
                              For object animation, it does not really make sense, since scenes would not capture the object movements.
                              And if you just need a camera animation, then create your scenes manually. Sketchup will animate the transition between scenes and you can even record the whole animation to a MP4 file.
                              • R
                                rclubb
                                @fredo6 said:
                                THOUGHTS?
                                Are there any plans for getting this to work with GPU rendering? I love the plugin and I would happily pay to have a version that would utilize the GPU.
                                I'm currently in the middle of a render with V-Ray that is going to take 17 hours for a 14 second clip with 211 frames at 785x800 resolution. Is there any way to cut down the time without killing any more of the quality? This is just for a test, I would like to render a much higher resolution.
                                My specs:
                                HP OMEN 30L
                                Ryzen 9 5900x
                                RTX 3090
                                • fredo6F
                                  fredo6
                                  No immdiate plan. Actually, I don't know yet how to do it and even if it is possible.
                                  • G
                                    Gelombaasue
                                    Antes que nada, muchas gracias por el plugin. La verdad es que es el mejor y el más completo que he encontrado para sketchup. No obstante, estaría muy bien que agregarán una opción para que de alguna manera las animaciones (o fotogramas) se puedan "guardar" directamente en sketchup y que más tarde uno pueda visualizarlas aún no teniendo el plugin (algo parecido a lo que hace el plugin keyframe), de este modo se tendrían más opciones para renderizar en cualquier motor de render que funcione con sketchup
                                    • A
                                      apdapd Newcomers
                                      看不到图标
                                      • A
                                        apdapd Newcomers
                                        @apdapd said:
                                        看不到图标
                                        • fredo6F
                                          fredo6
                                          Please upgrade to the latest version of LibFredo6.
                                          • R
                                            rown2000
                                            Hello Fredo, is there a possibility of using twilight render when making a video instead of vray?
                                            thanks, great job.
