    [Plugin] Animator - v4.6a - 18 Dec 25
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    602 Posts 120 Posters 2.3m Views 120 Watching
    • ntxdaveN
      ntxdave
      OK - If I have multiple layers to show/hide, I cannot get it to work correctly (at least the way I would like) using the duration greater than 0.
      Here is an example. I have 2 spray units. I have them at different times and different durations. They both turn on correctly but they do not turn off until after the 2nd layer is to be hidden.
      Multiple layer control - click to view
      I will try later using the original method of setting 0 duration for each layer to show and hide and see what happens. While this works, I was hoping the previous method would work as well. Maybe I am pushing the envelope a little too far. I will have multiple situations like this is a full wash. As previously stated, if a single control for each layer can be accomplished, IMO it would be much easier to manage.
      Is this way out of perspective ❓
      OK - I see what is going on is that each time any action is taken, it is for ALL layers. Thus I would need to break my example down and have 5 layer visibility captures:
      1. At beginning to capture the initial state of all layers
      2. Beginning of the first spray to turn that layer on and the other spray layer off
      3. Beginning of the second spray to turn that layer on and make sure the other layer is still on
      4. End of the first spray to turn that layer off and make sure the other spray is still on (since in the case there is actually some overlap
      5. End of the second spray to turn that layer off
      Is it out of the question to ask if it is possible to control each layer independently?
      Press F1...thank me later
      • ntxdaveN
        ntxdave
        @solo said:
        Trying to figure out how to do the water spray
        Have not heard/seen anything more from and was wondering where you were headed with.
        • JQLJ
          JQL
          Why don't you composite it using Natron or other similar software?
          www.casca.pt
          Visit us on facebook!
          • fredo6F
            fredo6
            New Release: Animator - v1.0v - 13 Jun 16
            Maintenance and small evolutions
            • Reworked the Movement engine to make it more contextual. This answers some valid requests by Pilou and Dave. See video below
            • Objects concerned by a movement are highlighted when mouse-over in the timeline. I still need to illustrate the movement itself
            • Possible assignment of color to a Clip element. This may help to distinguish them.
            • Bug fixing, in particular when creating new films and for random cases where the offset of transaltion was 'unset'
            • Cosmetic changes
            Note for the video:
            • The Rubiks cube is actualling 'orbiting' around the small cube. Orbiting means Rotation by a point which is attached to another object (versus absolute pivot).
            • It can however move by itself individually (the small jump)
            • The inside of the Rubiks cube is also animated
            • That why, in the second part of the video, the second instance only shows the movements within the Rubiks cube.
            See main post for RBZ files
            • ntxdaveN
              ntxdave
              • Cosmetic changes
              Note for the video:
              Some good enhancements. I am playing with these a little and having a point of reference for rotating (orbiting another object) will turn out to be valuable. Already playing with that a little.
              In particular, I like the ability to hover a sequence and get some visual feedback on which objects the sequence is attached to is REALLY valuable (IMO). I also like that I can color code a sequence so I can easily identify all of the sequences that belong to a given object visually. I think this will be another tool that can be used a lot.
              Here is good example. I have 2 panels of the garage door that I have animated. By color coding each panel, I can easily see which sequences belong to which panel.
              Garage Door Animation (WIP)
              • fredo6F
                fredo6
                About Orbiting, for the time being:
                • when you have clicked to select the pivot, you should click-right and choose the reference object if this is not the one taken by Animator or if you wish an absolute pivot.
                • The reference object for pivot is highlighted in Orange.
                I'll make the GUI more explicit in a next version.
                Fredo
                • fredo6F
                  fredo6
                  New Release: Animator - v1.0x - 08 Jul 16
                  • New Features
                  • Visual Effects: Layer visibility on-off (see tutorial)
                  • Visual Effects: zoom
                  • Cameras: Tracking Cameras (see tutorial)
                  • Cameras: Scene Cameras
                  • Support of Twilight Render Pro (thanks to Chris)
                  • Minimize timeline(to hide all palettes when playing animation) - see tutorial
                  • Maintenance - Fixes and adjustments
                  • Corrections for Rotation with orbiting
                  • Various bugs
                  • Cosmetic changes in GUI
                  Here are two videos
                  1) Tracking Cameras
                  2) Layer visibility: State and On-Off
                  • fredo6F
                    fredo6
                    chri,
                    Can you open the Ruby console to see what is going on
                    Fredo
                    • fredo6F
                      fredo6
                      Chri,
                      Thanks.
                      I fixed it and republish as LibFredo6 7.0x2 9 Jul 16 (Animator is unchanged)
                      Fredo
                      • fredo6F
                        fredo6
                        Actually, the X2 is not good. Take the 7.0x3.
                        Fredo
                        • chriC
                          chri
                          hi Fredo
                          the new release don't works for me
                          When i click on the icon ... nothing !
                          (i use SKETCHUP PRO 2014 AND WINDOWS XP )
                          Chri
                          • chriC
                            chri
                            @fredo6 said:
                            chri,
                            Fredo
                            message in Ruby console
                            Error: #<NoMethodError: undefined method `definition' for #Sketchup::Group:0x968a150>
                            • chriC
                              chri
                              Fredo
                              It works for me
                              Thanks Fredo
                              Chri
                                AmbientOcclusionEx v1.9.5.
                                TheaRender v1.5 (from Animator and in Batch from Thea)
                                SketchFX Ex v1.0.6
                                Twilight Render %(#FF0000)[Pro v3.5]
                                It's Twilight Render Pro v2.5! πŸ˜‰ (and I suppose also Hobby Version ? )
                                What is the process for use it with Twilight Render ?
                                • chriC
                                  chri
                                  Hi Fredo
                                  I have a problem to ROTATE.
                                  Please , have a look on the next GIF ( clic to anim )
                                  Chri
                                  • ntxdaveN
                                    ntxdave
                                    SketchFX Ex v1.0.6
                                    It is my understanding that only the Pro version can be used with Animator. We will have to wait and see when they post the link today.
                                      Idem! Seems there is blend of rotation / Object / General!
                                      • fredo6F
                                        fredo6
                                        @chri said:
                                        Hi Fredo
                                        Chri
                                        Thanks for signaling. Fixed.
                                        Fredo
                                        • fredo6F
                                          fredo6
                                          SketchFX Ex v1.0.6
                                          I think this is just for Pro version.
                                          Fredo
                                          • fredo6F
                                            fredo6
                                            [attachment=0:yeoqnx06]<!-- ia0 -->GIF_idem.gif<!-- ia0 -->[/attachment:yeoqnx06]
                                            Is there a bug there?
                                            • 30
                                            • 31
                                            • 2 / 31
