    [Plugin] Animator - v4.6a - 18 Dec 25
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    602 Posts 120 Posters 2.3m Views 120 Watching
    • M
      mast1987
      First: Big Thanks to FREDO for this Genius plugin.
      Theres just 1 Thing I got a Problem with: Camera Fade out.
      If I use more than 2 views/cameras the Animation stops at the second view/camera and doesnt fade to the third one.
      what did I wrong?
      • fredo6F
        fredo6
        what did I wrong?
        Could you please post or PM your model so that I have a look.
        Maybe you simply disable fadeout for the second camera.
        Fredo
        • M
          mast1987
          ok I got a solution:
          when i set the camera Position with the eye tool it doesnt works.
          when I set it with the Orbit and Hand tool it works fine.....
          thanks for the quick answer btw
          • fredo6F
            fredo6
            Glad to see it works.
            Still, I don't see why you have a difference, since Animator does not really care HOW you set a view: it just capture the camera when it is set.
            Fredo
            • fredo6F
              fredo6
              New Release: Animator - v1.8b - 19 Nov 17
              Requirement: LibFredo6 v8.0b
              Maintenance release
              • bug fixing
              • Handling of cases where scenes which are part of an animation are deleted in Sketchup.
              • improvement in circular camera interpolation (fadeout) if you also install LibFredo6 8.0b
              See main post for RBZ files
              • M
                Mike598601
                Just upgraded VRay to 3.6 but it no longer appears in the 'Render with' options in animator - is this version of Vray supported by animator in SU 2018?
                • fredo6F
                  fredo6
                  Is Vray 3.6 installed in SU2018?
                  I will investigate on my side
                  Fredo
                  • soloS
                    solo
                    Go home Thea, you're drunk!
                    Why is Thea acting like a drunk uncle? see the animation in SU, this is what I want to render in Thea:
                    However, when I choose to render the animation I get this:
                    Is there a way to fix this? reset Thea in some way?
                    http://www.solos-art.com
                    • ntxdaveN
                      ntxdave
                      I am assuming that when you went to create the animation using the Animator plugin you clicked the Thea button. I have not seen anything like that happen but I have not used Animator for a while
                      Press F1...thank me later
                      • soloS
                        solo
                        If I did not press the Thea button then it would not have rendered with Thea, I did what I always do, use Thea animation with the Animator plugin selected.
                        Besides Thea, does Animator support other renderers? may be time to move on.
                        • ntxdaveN
                          ntxdave
                          I remember for sure that it also supports Twilight Pro and Ambient Occlusion. Not sure which others.
                          Yes, I thought that is what you did (clicked). I guess I was "grasping at a straw" for an explanation but I know you are much more of a sage that that. Dumb remark/question on my pattern. 😳
                          Hope you get this sorted out.
                          • fredo6F
                            fredo6
                            Solo,
                            Did you generate the rendered animation from within Animator, or from Thea animation ?
                            I guess the best to understand what could be going on is to send me the model.
                            Fredo
                            • soloS
                              solo
                              @fredo6 said:
                              Solo,
                              Fredo
                              I tried with Animator but for some reason that failed to do anything, I interrupted after 10 minutes only to find an empty folder, no images were saved so I then rendered within the Thea window and got the messed up result.
                              Here is the basic model with animation set up.
                              sorril t.skp
                              • ntxdaveN
                                ntxdave
                                It has been a while since I tried anything with Thea but so far all I am getting is a black screen. No content!!
                                I am rendering it with Twilight though. I will share that when I am done rendering it (going pretty fast).
                                • soloS
                                  solo
                                  You are getting a black screen because you do not have an HDRi in the illumination slot, the sun is switched off.
                                  • ntxdaveN
                                    ntxdave
                                    Still working on it Pete. Creating an MP4 with Thea did not work correctly and I had a problem trying to create a GIF. In the process again.........
                                    • ntxdaveN
                                      ntxdave
                                      I did not do a good job but at least you can see that both of these render engines will work correctly with Animator (if you know how to user the renderers).
                                      Thea
                                      Twilight
                                      • soloS
                                        solo
                                        Interesting, I had someone on the Thea forums test it out and they also got an abnormal result, now I'm more confused.
                                        • ntxdaveN
                                          ntxdave
                                          Maybe it has something to do with versions:
                                          • Your skp file: SU Version 8.0.1
                                          • I used SU: Version 2017 Pro
                                          • I used Thea: Version TheaForSketchUpBundle_v1.5.07.480.1447
                                          • I used Animator: Version 1.8a
                                          • I used Fredo LibFredo6: Version 8.0a
                                          Do not know if that will shed any light on things but maybe I have something in versions might make a difference. If there is anything else I can do to help (other than a nice clean render), just let me know.
                                          • soloS
                                            solo
                                            I have the most recent version as well as new LibFredo v8
                                            I am using SU 2018 pro and Windows 10, I just saved model as V8 for those that do not have new SU versions.
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 30
                                            • 31
                                            • 11 / 31
