    [Plugin] Animator - v4.5a - 22 Jul 25
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    547 Posts 119 Posters 1.8m Views 119 Watching
    • fredo6F Offline
      fredo6
      New Release: Animator - v2.2c - 26 Aug 18
      Requirement: LibFredo6 v8.5a
      Minor release
      • Extension of validity
      • Fix a problem coming from using transparent move! for performance, signaled by ithil
      See plugin home page of Animator for Download of RBZ from the PluginStore.
      See Main Post of the Animator thread for more information.
        Takkegek
        Hi Fredo, I did some other tests with the plugin. But I was wondering, is it also possible to have a sun animation in these videos I made ( with thea render and animator ) ? So I want all the movement of the objects + sun animation ( from dusk till dawn for example), is this possible?
        other little thing: there is 'no clip defined in model' when I want to start animation render in thea render sketchup ( not animator). Even if I have the license done. Rendering from animator is no problem though.
        • fredo6F Offline
          fredo6
          Sun is supported (using Shadow Visual Effect). Just put two elements in the timeline with different dates and Animator will interpolate the shadows between the two.
          Fred
            Takkegek
            Thanks Fredo, I will try this!
              studzinski
              Hi, I have created a staging animation in SU for a construction of a metro station, an 8min video, approx. 160 scenes, showing how the station will be built from start to finish, with construction equipment, etc. I am looking for someone to turn this into a more photo realistic animation, add some movement to the construction equipment, etc. Animator seems like the right tool, though I have never used it myself. Is there someone that would be interested and had immediate availability to do this for me?
              Regards,
              Michal
                bulet
                Cannot find the explode function in the latest version.
                Please advise.
                • fredo6F Offline
                  fredo6
                  It is in the Movement palette
                  • ArcA Offline
                    Arc
                    It is chinese translation, 100%.
                    Animator_ZH.lang
                      bulet
                      [attachment=0:83dt0fyt]<!-- ia0 -->Animator explosion.png<!-- ia0 -->[/attachment:83dt0fyt]
                      Thank you. Found it. Was a bit confused with the route.
                      • V Offline
                        Valy2404
                        Hi Fredo. when I export animation or render plugin writes that it needs a Pro version where I can fix it or buy a Pro version ?
                        • V Offline
                          Valy2404
                          • fredo6F Offline
                            fredo6
                            New Release: Animator - v2.3a - 14 Nov 18
                            Requirement: LibFredo6 v8.6k
                            Minor release
                            • Mouse Wheel can now be used for scrolling on Mac platforms
                            • Various bug fixing
                            • P Offline
                              palphd
                              Hi Fredo,
                              Is there an option for achieving transparent backgrounds when generating a video as an images sequence (PNGs)?
                              Cheers,
                              Chris
                              • fredo6F Offline
                                fredo6
                                Chris
                                Good point. I have to test, but it should be possible. I'll have to add the option in the GUI too.
                                Fredo
                                • P Offline
                                  palphd
                                  @fredo6 said:
                                  Chris
                                  Fredo
                                  Thanks so much for the reply! Animator is such a fantastic plugin, but I was going insane trying to find that option since MSPhysics and ClothWorks have it. Adding it to Animator will truly complete the SketchUp animation trifecta as far as I'm concerned.
                                  Good luck and thanks again! πŸ‘ I'll stay tuned 😎
                                  Cheers,
                                  Chris*
                                  • fredo6F Offline
                                    fredo6
                                    New Release: Animator - v2.3b - 16 Nov 18
                                    Minor release
                                    • Mouse Wheel for scrolling now works in parallel projection mode
                                    • fredo6F Offline
                                      fredo6
                                      New Release: Animator - v2.3c - 18 Nov 18
                                      Requirement: LibFredo6 v8.6m
                                      Minor release
                                      • Bug fixing and GUI adjustments
                                      • Option for Transparent background for generating videos. It only works for Natural rendering and generate the PNG images with no background. I don't know if this makes its way through the video generation via FFmpeg. You need to install LibFredo6 8.6m.
                                      • P Offline
                                        palphd
                                        Minor release
                                          [attachment=0:1f6ufy1r]<!-- ia0 -->Animator - Transparent Background toggle button.png<!-- ia0 -->[/attachment:1f6ufy1r]
                                        Thanks Fredo,
                                        Good news: I can now see the Transparent Background toggle button on the GUI.
                                        Bad news: I don't get transparent backgrounds in my PNGs when I export them with the option selected 😞
                                        • fredo6F Offline
                                          fredo6
                                          Did you upgrade to LibFredo6 8.6m?
                                          • P Offline
                                            palphd
                                            That did the trick! You're the man, Fredo!
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 27
                                            • 28
                                            • 15 / 28
