    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • T
      Takkegek
      Thanks Fredo, I will try this!
        studzinski
        Hi, I have created a staging animation in SU for a construction of a metro station, an 8min video, approx. 160 scenes, showing how the station will be built from start to finish, with construction equipment, etc. I am looking for someone to turn this into a more photo realistic animation, add some movement to the construction equipment, etc. Animator seems like the right tool, though I have never used it myself. Is there someone that would be interested and had immediate availability to do this for me?
        Regards,
        Michal
        • B
          bulet
          Cannot find the explode function in the latest version.
          Please advise.
          • fredo6F
            It is in the Movement palette
            • ArcA
              Arc
              It is chinese translation, 100%.
              Animator_ZH.lang
              • B
                bulet
                [attachment=0:83dt0fyt]<!-- ia0 -->Animator explosion.png<!-- ia0 -->[/attachment:83dt0fyt]
                Thank you. Found it. Was a bit confused with the route.
                • V
                  Valy2404
                  Hi Fredo. when I export animation or render plugin writes that it needs a Pro version where I can fix it or buy a Pro version ?
                  • V
                    Valy2404
                    • fredo6F
                      New Release: Animator - v2.3a - 14 Nov 18
                      Requirement: LibFredo6 v8.6k
                      Minor release
                      • Mouse Wheel can now be used for scrolling on Mac platforms
                      • Various bug fixing
                      See plugin home page of Animator for Download of RBZ from the PluginStore.
                      See Main Post of the Animator thread for more information.
                      • P
                        palphd
                        Hi Fredo,
                        Is there an option for achieving transparent backgrounds when generating a video as an images sequence (PNGs)?
                        Cheers,
                        • fredo6F
                          Good point. I have to test, but it should be possible. I'll have to add the option in the GUI too.
                          • P
                            palphd
                            @fredo6 said:
                            Thanks so much for the reply! Animator is such a fantastic plugin, but I was going insane trying to find that option since MSPhysics and ClothWorks have it. Adding it to Animator will truly complete the SketchUp animation trifecta as far as I'm concerned.
                            Good luck and thanks again! πŸ‘ I'll stay tuned 😎
                            Cheers,
                            Chris*
                            • fredo6F
                              New Release: Animator - v2.3b - 16 Nov 18
                              Minor release
                              • Mouse Wheel for scrolling now works in parallel projection mode
                              • fredo6F
                                New Release: Animator - v2.3c - 18 Nov 18
                                Requirement: LibFredo6 v8.6m
                                Minor release
                                • Bug fixing and GUI adjustments
                                • Option for Transparent background for generating videos. It only works for Natural rendering and generate the PNG images with no background. I don't know if this makes its way through the video generation via FFmpeg. You need to install LibFredo6 8.6m.
                                • P
                                  palphd
                                  Minor release
                                    [attachment=0:1f6ufy1r]<!-- ia0 -->Animator - Transparent Background toggle button.png<!-- ia0 -->[/attachment:1f6ufy1r]
                                  Thanks Fredo,
                                  Good news: I can now see the Transparent Background toggle button on the GUI.
                                  Bad news: I don't get transparent backgrounds in my PNGs when I export them with the option selected 😞
                                  • fredo6F
                                    Did you upgrade to LibFredo6 8.6m?
                                    • P
                                      palphd
                                      That did the trick! You're the man, Fredo!
                                        rong1937
                                        Hope to support Enscape render
                                        • C
                                          chals375
                                          Hello.
                                          First of all, I hope you understand the awkwardness of English.
                                          Writing on the translator.
                                          I used the animator 2.1a version and thea render v2.Β
                                          I was using it well, but after updating the animator to 2.3c, I can't turn it on.
                                          When I press the render button, the word "no clip defined in model" appears.
                                          So do files with dozens of clips.
                                          Everything went dead.
                                          I want to use version 2.1a again, but it is not possible because the period of use has expired.
                                          If I set my computer time to the past, I can use it, but because thea render license is not available, rendering is not possible.
                                          How shall I do it?
                                          Please help me.T.T
                                          • fredo6F
                                            @chals375
                                            1. First of all, can you play the animation interactively within Animator
                                            2. Can you generate the video in natural mode (No rendering by Thea)?
                                            3. Can you open the Ruby console while you are in Animator, to see i there are errors showing.
                                            Finally, the best would be that you post or PM me your model so that I can have a closer look.
                                            PS: do not play with the clock of your PC, as you can have many other bad side effects on other applications.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 29
                                            • 30
                                            • 15 / 30
