    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • ArcA
      Arc
      It is chinese translation, 100%.
      Animator_ZH.lang
      • B
        bulet
        @fredo6 said:
        @bulet said:
        Cannot find the explode function in the latest version.
        It is in the Movement palette
        [attachment=0:83dt0fyt]<!-- ia0 -->Animator explosion.png<!-- ia0 -->[/attachment:83dt0fyt]
        Thank you. Found it. Was a bit confused with the route.
        • V
          Valy2404
          Hi Fredo. when I export animation or render plugin writes that it needs a Pro version where I can fix it or buy a Pro version ?
          • V
            Valy2404
            • fredo6F
              New Release: Animator - v2.3a - 14 Nov 18
              Requirement: LibFredo6 v8.6k
              Minor release
              • Mouse Wheel can now be used for scrolling on Mac platforms
              • Various bug fixing
              See plugin home page of Animator for Download of RBZ from the PluginStore.
              See Main Post of the Animator thread for more information.
              • P
                palphd
                Hi Fredo,
                Is there an option for achieving transparent backgrounds when generating a video as an images sequence (PNGs)?
                Cheers,
                • fredo6F
                  Good point. I have to test, but it should be possible. I'll have to add the option in the GUI too.
                  • P
                    palphd
                    @fredo6 said:
                    Thanks so much for the reply! Animator is such a fantastic plugin, but I was going insane trying to find that option since MSPhysics and ClothWorks have it. Adding it to Animator will truly complete the SketchUp animation trifecta as far as I'm concerned.
                    Good luck and thanks again! πŸ‘ I'll stay tuned 😎
                    Cheers,
                    Chris*
                    • fredo6F
                      New Release: Animator - v2.3b - 16 Nov 18
                      Minor release
                      • Mouse Wheel for scrolling now works in parallel projection mode
                      • fredo6F
                        New Release: Animator - v2.3c - 18 Nov 18
                        Requirement: LibFredo6 v8.6m
                        Minor release
                        • Bug fixing and GUI adjustments
                        • Option for Transparent background for generating videos. It only works for Natural rendering and generate the PNG images with no background. I don't know if this makes its way through the video generation via FFmpeg. You need to install LibFredo6 8.6m.
                        • P
                          palphd
                          Minor release
                            [attachment=0:1f6ufy1r]<!-- ia0 -->Animator - Transparent Background toggle button.png<!-- ia0 -->[/attachment:1f6ufy1r]
                          Thanks Fredo,
                          Good news: I can now see the Transparent Background toggle button on the GUI.
                          Bad news: I don't get transparent backgrounds in my PNGs when I export them with the option selected 😞
                          • fredo6F
                            Did you upgrade to LibFredo6 8.6m?
                            • P
                              palphd
                              That did the trick! You're the man, Fredo!
                                rong1937
                                Hope to support Enscape render
                                • C
                                  chals375
                                  Hello.
                                  First of all, I hope you understand the awkwardness of English.
                                  Writing on the translator.
                                  I used the animator 2.1a version and thea render v2.Β
                                  I was using it well, but after updating the animator to 2.3c, I can't turn it on.
                                  When I press the render button, the word "no clip defined in model" appears.
                                  So do files with dozens of clips.
                                  Everything went dead.
                                  I want to use version 2.1a again, but it is not possible because the period of use has expired.
                                  If I set my computer time to the past, I can use it, but because thea render license is not available, rendering is not possible.
                                  How shall I do it?
                                  Please help me.T.T
                                  • fredo6F
                                    @chals375
                                    1. First of all, can you play the animation interactively within Animator
                                    2. Can you generate the video in natural mode (No rendering by Thea)?
                                    3. Can you open the Ruby console while you are in Animator, to see i there are errors showing.
                                    Finally, the best would be that you post or PM me your model so that I can have a closer look.
                                    PS: do not play with the clock of your PC, as you can have many other bad side effects on other applications.
                                    • T
                                      Tranthanhvu
                                      Can you help me.
                                      https://youtu.be/eLUiA4i01Yo
                                      • fredo6F
                                        @tranthanhvu said:
                                        Can you help me.
                                        For the rotation, you need to select the two arms objects, instead of the components which includes both arms.
                                        • C
                                          Comial
                                          @fredo6 said:
                                          @chals375
                                          I'm having the same issue since upgrading to v2.3. In response to your questions to @chals375
                                          1. Yes, I can play the animation without any problems in Animator
                                          2. Yes, I can generate the video in natural mode. Also, Thea render's animation tab can render Sketchup default animations but does not open a dialog when selecting Animator as the plugin.
                                          3. Ruby console does not display any errors when trying to render from Thea Render
                                          Rendering with Thea works just fine if I initiate it from Animator, but the only reason I want to render from Thea is so that I have control over what format the exported image sequence is in. If there is a way to do that from Animator then that would also solve my problem.
                                          PS. I love all your plugins. Thank you for all your contributions to the Sketchup community!!
                                          • fredo6F
                                            I fixed the issue with the generation from Thea render in Animator 2.4a.
                                            Please advise if this is ok for your now.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 29
                                            • 30
                                            • 15 / 30
