    1963 Ac cobra Mk 1 260/289
    22 Posts 8 Posters 8.2k Views 8 Watching
    • garydornG
      garydorn
      In a an attempt to learn how to do organic modelling with sketch up, I decided to start with an AC Aceca, following CaljuCotcas tutorial on how to model a car in 3D using blueprints
      https://www.youtube.com/watch?v=Hgrix3m1l9k.
      Eventhough 3D warehouse has 427 examples, I prefer the shape of the 289.
      I have a collection of drawings and downloaded blueprints, so I've started. I also have a Shelby collectable die cast model 1:24 scale and a set of chassi and competent drawings ( leaf spring chassi) which I've also been modelling up.
      The intent is to completely model the whole car - Ie chassi, suspension, steering, body subframe, body
      WIP cobra 260 model
      WIP chassi model
      the real things cxs 2104
      • garydornG
        garydorn
        I've further simplified the lines to make more like rectangles/quads so the subD could eventually be applied.
        I had a go at running sandbox - from contours - rubbish result.
        sand box - from contours
          I would think Artisan would be the place to go.
          • ntxdaveN
            ntxdave
            Check out this thread: http://sketchucation.com/forums/viewtopic.php?f=397%26amp;t=63826%26amp;start=330
            I think you will see some examples there that you will like and it might give you some more ideas about how to get where you are going. The thread has several examples of people drawing cars using the QuadFaceTools, VertexTools, and SubD plugins.
            Looks like you are off to a good start though. I would like to learn how to do this kind of stuff as well.
            Press F1...thank me later
            • BoxB
              Ummm Dave, he has already posted in that thread and even on the specific page you linked to.
              • ntxdaveN
                ntxdave
                Ooops - missed that. Someone should delete my post then...
                • hellnbakH
                  hellnbak
                  Alright, someone actually modeling a car! (I want to put a smilie here, but of course the one I want to use has been unceremoniously done away with, along with all the other good ones everybody actually liked to use)
                  • garydornG
                    garydorn
                    part of the difficulty I am finding is working out where to put the lines.
                    This post by Rich O'Brien shows an interesting position of line around the front corner. Also it is a 427
                    @rich o brien said:
                    [edg3d:3htxz53g]6dOQrvWoC7Uy1vP[/edg3d:3htxz53g]
                    This is my effort so far.
                    real 289 - front right corner  This is the required look.
                    • garydornG
                      garydorn
                      I've re-jigged the wire frame such that follows more closely the Quads format - but still have some 3 sided and 5 side edges to sort out.
                      ![wire frame as "quads"](/uploads/imported_attachments/X6DP_wireframe.png "wire frame as "quads"")
                      wire frame now with triangulated surfaces
                      I am having a bit of trouble with the cockpit shoulder
                      • garydornG
                        garydorn
                        smoothed body with wire wheelsIve now divided and grouped the various sections - nose, hood, fender, side, rear, and smoothed each surface,
                        also added some wire wheels from 3D warehouse .
                        junction of front hose/hood light still sorting out.
                        update to front nose to light transition
                        shelby collectable nose -light transition
                        • garydornG
                          garydorn
                          Just because I can - I've exported the SU model to DWG - edges, faces geometry.
                          Then I imported into Boa - an Architecture solids modeller that only uses a 6 sided block. (every face has 4 edges ) http://boa-research.fr
                          In Boa I then started to insert a 3mm thick solid block over the mesh. Because the 4 corners a not in a flat plane the last point shows up how far it is out.
                          Boa can also do a 3 edge face, by automatically dividing the face into 3 equal blocks - so I gave that a try also.
                          Eventually Im interested to see how the Quad faces align with each when comparing my hand/eye construction with the Quadface and SubD tools.
                          Boa - solids over mesh
                          Boa - tri face solid over mesh
                          • garydornG
                            garydorn
                            After doing some more online reading of quads and subs , I've reduced the number of mesh on bonnet and boot lid, and then opening up my trial version of SU 2013 and downloading artisan, contour maker , slicer and Topo shaper, I tried each to see what happened.
                            Apart from the wheel archs - which have been smoothed too much, and the centre line of hood being not flat enough, Artisans version its getting pretty close.
                            Slicer with y and Z set to 150mm created some profiles. For some reason X said nothing to create!
                            Contour maker set at 50mm greeting an interesting shape
                            Topo shaper I guess is for terrains - although if you want to have a car cover - its may well be the tool to do the job!
                            artisan version of body
                            slicers Y and Z profiles
                            contours @ 50mm
                            toposhaper - a draped mesh?
                            • garydornG
                              garydorn
                              Here is the SU files - saved as SU6 from SU 13 trial version
                              Mos tof the modelling has been done in SU 6 - with some touch ups/adjustments in SU 13
                              sketchUp 6 file of 260/289 body WIR
                              • ely862meE
                                ely862me
                                You are on the right path, don't get drown at the shore.
                                I have retouched the shape overall and made it compatible with SubD.
                                About an hour and a half worked on it(it still needs a couple of touches here and there).. boy I miss car modeling !!
                                Elisei (sketchupper)
                                Come and See EliseiDesign
                                • garydornG
                                  garydorn
                                  wow
                                  I've downloaded your file posted on the SubD chat.http://sketchucation.com/forums/download/file.php?id=137307
                                  I am curious,
                                  for the front wheel to fender transition you carried the wheel flare loop all the way across under the front to the other wheel.
                                  is that a deliberate mesh strategy.
                                  front wheel flare continuouse loop
                                  The rear hip line has a nice flow.
                                  hip lines
                                  • ely862meE
                                    ely862me
                                    @garydorn said:
                                    wow
                                    I am curious,
                                    Yes, it is a bit of a strategy as it is good to have continuous loops. You can end the detail somewhere near the other loop, but it will break the surface a bit and I don't like triangles.
                                      Elisei, nicely done Sir, quite brilliant in fact.
                                      • garydornG
                                        garydorn
                                        For reference , there a number of photos of wooden bucks there were supposedly originally used to hammer out aluminium skins for these bodies.
                                        https://s-media-cache-ak0.pinimg.com/736x/ba/3a/38/ba3a387825743e2ced2f1388fb723330.jpg
                                        https://c1.staticflickr.com/9/8032/8051605973_1bed2902ce_b.jpg
                                        http://www.clubcobra.com/photopost/data/500/1412470_318783218259863_98733977_o.jpg
                                        https://scontent-syd1-1.xx.fbcdn.net/hphotos-xtf1/v/t1.0-9/11046579_402587893199542_8233608334097962867_n.jpg?oh=f4138a388b2bc2d77557398118e9e783&oe=576DE8E3
                                        https://scontent-syd1-1.xx.fbcdn.net/hphotos-xal1/v/t1.0-9/11110_393631437428521_6918278704604256187_n.jpg?oh=d2ad79659ac9547b0d55b32dcd65b4e4&oe=5754D12D
                                        https://scontent-syd1-1.xx.fbcdn.net/hphotos-prn2/v/t1.0-9/1239866_262077007250632_2124446986_n.jpg?oh=07280724279d0e108897f8d8f9108f30&oe=5753B477
                                        credit to original photographers.
                                        https://www.facebook.com/TeamAC/photos_stream
                                        • garydornG
                                          garydorn
                                          Looking closer at these wooden bucks , and you can see the 'Quads" all over the place!
                                          • garydornG
                                            garydorn
                                            I have a set of technical drawing for the seat frame and some photos, so I had a go at modelling up frame and seat pan.
                                            seat frame with pan seat frame model
                                            seat with pan ac seat jig
                                            • 1 / 2
