    1963 Ac cobra Mk 1 260/289
    22 Posts 8 Posters 6.9k Views 8 Watching
    • ntxdaveN Offline
      ntxdave
      @box said:
      Ummm Dave, he has already posted in that thread and even on the specific page you linked to.
      Ooops - missed that. Someone should delete my post then...
      Press F1...thank me later
      • hellnbakH Offline
        hellnbak
        Alright, someone actually modeling a car! (I want to put a smilie here, but of course the one I want to use has been unceremoniously done away with, along with all the other good ones everybody actually liked to use)
        • garydornG Offline
          garydorn
          part of the difficulty I am finding is working out where to put the lines.
          This post by Rich O'Brien shows an interesting position of line around the front corner. Also it is a 427
          @rich o brien said:
          [edg3d:3htxz53g]6dOQrvWoC7Uy1vP[/edg3d:3htxz53g]
          This is my effort so far.
          real 289 - front right corner  This is the required look.
          • garydornG Offline
            garydorn
            I've re-jigged the wire frame such that follows more closely the Quads format - but still have some 3 sided and 5 side edges to sort out.
            ![wire frame as "quads"](/uploads/imported_attachments/X6DP_wireframe.png "wire frame as "quads"")
            wire frame now with triangulated surfaces
            I am having a bit of trouble with the cockpit shoulder
            • garydornG Offline
              garydorn
              smoothed body with wire wheelsIve now divided and grouped the various sections - nose, hood, fender, side, rear, and smoothed each surface,
              also added some wire wheels from 3D warehouse .
              junction of front hose/hood light still sorting out.
              update to front nose to light transition
              shelby collectable nose -light transition
              • garydornG Offline
                garydorn
                Just because I can - I've exported the SU model to DWG - edges, faces geometry.
                Then I imported into Boa - an Architecture solids modeller that only uses a 6 sided block. (every face has 4 edges ) http://boa-research.fr
                In Boa I then started to insert a 3mm thick solid block over the mesh. Because the 4 corners a not in a flat plane the last point shows up how far it is out.
                Boa can also do a 3 edge face, by automatically dividing the face into 3 equal blocks - so I gave that a try also.
                Eventually Im interested to see how the Quad faces align with each when comparing my hand/eye construction with the Quadface and SubD tools.
                Boa - solids over mesh
                Boa - tri face solid over mesh
                • garydornG Offline
                  garydorn
                  After doing some more online reading of quads and subs , I've reduced the number of mesh on bonnet and boot lid, and then opening up my trial version of SU 2013 and downloading artisan, contour maker , slicer and Topo shaper, I tried each to see what happened.
                  Apart from the wheel archs - which have been smoothed too much, and the centre line of hood being not flat enough, Artisans version its getting pretty close.
                  Slicer with y and Z set to 150mm created some profiles. For some reason X said nothing to create!
                  Contour maker set at 50mm greeting an interesting shape
                  Topo shaper I guess is for terrains - although if you want to have a car cover - its may well be the tool to do the job!
                  artisan version of body
                  slicers Y and Z profiles
                  contours @ 50mm
                  toposhaper - a draped mesh?
                  • garydornG Offline
                    garydorn
                    Here is the SU files - saved as SU6 from SU 13 trial version
                    Mos tof the modelling has been done in SU 6 - with some touch ups/adjustments in SU 13
                    sketchUp 6 file of 260/289 body WIR
                    • ely862meE Offline
                      ely862me
                      You are on the right path, don't get drown at the shore.
                      I have retouched the shape overall and made it compatible with SubD.
                      About an hour and a half worked on it(it still needs a couple of touches here and there).. boy I miss car modeling !!
                      Elisei (sketchupper)
                      Come and See EliseiDesign
                      • garydornG Offline
                        garydorn
                        wow
                        I've downloaded your file posted on the SubD chat.http://sketchucation.com/forums/download/file.php?id=137307
                        I am curious,
                        for the front wheel to fender transition you carried the wheel flare loop all the way across under the front to the other wheel.
                        is that a deliberate mesh strategy.
                        front wheel flare continuouse loop
                        The rear hip line has a nice flow.
                        hip lines
                        • ely862meE Offline
                          ely862me
                          @garydorn said:
                          wow
                          I am curious,
                          Yes, it is a bit of a strategy as it is good to have continuous loops. You can end the detail somewhere near the other loop, but it will break the surface a bit and I don't like triangles.
                            Elisei, nicely done Sir, quite brilliant in fact.
                            • garydornG Offline
                              garydorn
                              For reference , there a number of photos of wooden bucks there were supposedly originally used to hammer out aluminium skins for these bodies.
                              https://s-media-cache-ak0.pinimg.com/736x/ba/3a/38/ba3a387825743e2ced2f1388fb723330.jpg
                              https://c1.staticflickr.com/9/8032/8051605973_1bed2902ce_b.jpg
                              http://www.clubcobra.com/photopost/data/500/1412470_318783218259863_98733977_o.jpg
                              https://scontent-syd1-1.xx.fbcdn.net/hphotos-xtf1/v/t1.0-9/11046579_402587893199542_8233608334097962867_n.jpg?oh=f4138a388b2bc2d77557398118e9e783&oe=576DE8E3
                              https://scontent-syd1-1.xx.fbcdn.net/hphotos-xal1/v/t1.0-9/11110_393631437428521_6918278704604256187_n.jpg?oh=d2ad79659ac9547b0d55b32dcd65b4e4&oe=5754D12D
                              https://scontent-syd1-1.xx.fbcdn.net/hphotos-prn2/v/t1.0-9/1239866_262077007250632_2124446986_n.jpg?oh=07280724279d0e108897f8d8f9108f30&oe=5753B477
                              credit to original photographers.
                              https://www.facebook.com/TeamAC/photos_stream
                              • garydornG Offline
                                garydorn
                                Looking closer at these wooden bucks , and you can see the 'Quads" all over the place!
                                • garydornG Offline
                                  garydorn
                                  I have a set of technical drawing for the seat frame and some photos, so I had a go at modelling up frame and seat pan.
                                  seat frame with pan seat frame model
                                  seat with pan ac seat jig
                                  • Z Offline
                                    ZahariStoyanov
                                    Looking forward to seeing where this will go! πŸ˜„
                                      db11
                                      Lots of cool historical car stuff on this thread, but as a woodworker I find these wooden bucks even more compelling as pieces of art than the (gorgeous) auto body that was hammered out on top of them!
