    โš ๏ธ Attention | Having issues with Sketchucation Tools 5? Report Here
    SubD examples and models
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    1.7k Posts 81 Posters 975.3k Views 79 Watching
    • BoxB Offline
      You've spent too much time with the twins Rich.
      • BoxB Offline
        A bit of SUbD Bling.
        from this
        we get this.
        • pbacotP Offline
          Wow! would like to see detail on the necklace before and after and the links detail!
          • BoxB Offline
            I'm in the Doc's waiting room at the moment. I'll knock something up when I get back home.
            • HornOxxH Offline
              HornOxx
              ๐Ÿ‘ ๐Ÿ˜„ so cool again Box - how did you get the individual limbs so well strung up next to each other?
              never trust a skinny cook
              • BoxB Offline
                That's what I meant with my last line about using your choice of Stringer. There are a few to choose from, from memory
                Component Stringer by Chris Fulmer
                Comp String by Sam D Mitch
                Path Copy by Smustard
                or in this case Copy Along Curve by Anton S.
                I rendered another after laying the links down flat to the body.
                • BoxB Offline
                  Here you go, Unfortunately I can't fully unSUbD it but you get the idea. Each link starts as just a square doughnut that has been twisted with vertex tools.
                  Why describe when you can do.
                  Like this,
                  then distribute with your choice of stringer.
                  • BoxB Offline
                    SUbD is very helpful when basket weaving. A bit of clothworks thrown in for good measure.
                      I could use one of those chairs right now... ๐Ÿ˜„
                      • HornOxxH Offline
                        HornOxx
                        ๐Ÿ˜„ end of may and already 32ยฐC - Iยดll take such a chair also ๐Ÿ˜„ Really excellent Box!
                        • BoxB Offline
                          Something a little different. I'd call it Modern Retro with a nod to Spiderman.
                          It's got that late sixties early seventies molded plastic feel but perhaps made with updated materials and processes.
                          • cottyC Offline
                            cotty
                            Very nice!
                            my SketchUp gallery
                            • BoxB Offline
                              Here's a little silliness for those that wonder about making parts fit together or that everything has to be a soft curve.
                              The lid fits accurately although it is a separate component and the rubber/plastic seal around the electric cord has defined edges while still being part of the main component.
                              It is made up of only two parts, the main body including the power cord and the lid.
                              Although I must admit I haven't created the hinge section, nor have I done the plug as there are so many variations of them around the world. Not many here would be looking for an Australian plug.
                              I'll add the proxy if anyone wants to do the hinge and their own plug.
                              KettleProxy.skp
                              • boofredlayB Offline
                                boofredlay
                                Great!
                                • BoxB Offline
                                  Thanks Cotty, Boo ๐Ÿ‘
                                  Something to keep in mind, SUbD isn't just about organic modelling.
                                  It's about low poly to high poly. But it can be easily used on medium poly to smooth everything nicely before rendering.
                                  Here you see how something that is fairly blocky, but not low poly can be smoothed out with a quick bit of SUbD. Sometimes you want to render a whole model that is well constructed but not so overdone with segments that you get bogged down, but you'd like to do some close up of parts that may not be as smooth as you would want. Rather than having to redraw them with more segments just for the closeup, if well constructed to begin with, a quick subd to smooth is all you need.
                                  Model
                                  Before SUbD
                                  After SUbD
                                    Enlighting! ๐Ÿ˜Ž
                                    • FrederikF Offline
                                      Frederik
                                      ๐Ÿ‘ Good point...
                                      I know that a lot of other 3D modelling applications are utilizing this in a much wider extend...
                                      3dMax have the Turbo Smooth option...
                                      If users import such model into i.e. SU, they look really edgy...
                                      Cheers
                                      Kim Frederik
                                      • BoxB Offline
                                        Yeah, might be able to fix some models, but I can imagine there might be problems with triangulation and SUbD.
                                        But throw in a few blades and some hex screws...
                                        • utilerU Offline
                                          utiler
                                          That's extraordinary, Box!! ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
                                          • BoxB Offline
                                            Thanks Andrew but it's not that extraordinary really, just the magic of render software with a very simple model.
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 82
                                            • 83
                                            • 59 / 83
