    βŒ› Sale Ending | 30% Off Profile Builder 4 ends 30th September
    SubD examples and models
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    1.7k Posts 81 Posters 973.6k Views 79 Watching
    • BoxB Offline
      Any hint I give will make it too easy, think it through, what somewhat minor plugin makes SUbD work better.
      • cottyC Offline
        cotty
        Split Tools?
        my SketchUp gallery
        • BoxB Offline
          Well now when you say that Cotty, split tools is technically 2 different plugins, two by Tig and one by Rich. So I'll have to say no.
          • cottyC Offline
            cotty
            [Plugin] TIG.splitdonut
            my SketchUp gallery
            • BoxB Offline
              So all the plugins are?
              I have to be sure you know.
              • cottyC Offline
                cotty
                QFT, VertexTools, JPP and TIG.splitdonut?
                my SketchUp gallery
                • BoxB Offline
                  Excellent, now can you show me how?
                  • BoxB Offline
                    Only joking, I've hijacked the thread enough already.
                    Problem is I posted the same question on my FB page so I'll be giving it away here. I've got my eye on you facebook lurkers.
                    • HornOxxH Offline
                      HornOxx
                      πŸ‘ πŸ‘ I want to subscribe to your BOX Gif Channel !!!! πŸ˜„ πŸ˜„
                      Box, when you pull out all these selected squares with joint-push-pull, how do you succeed. that they taper like pyramids during this process at the same time?
                      never trust a skinny cook
                      • BoxB Offline
                        @hornoxx said:
                        Box, they taper like pyramids during this process at the same time?
                        On the toolbar that appears when you use JPP you have an option for taper.
                        As to the other go to facebook.com/boxgifs and enjoy.
                        • cottyC Offline
                          cotty
                          And if you don't see these options, you have to search for the "more options..." button.
                          my SketchUp gallery
                          • HornOxxH Offline
                            HornOxx
                            thank you guys πŸ˜„ and finally learned this vocabulary
                            • BoxB Offline
                              Here's one I posted way back.
                              If you had been following my FB Page you would have it sorted by now. πŸ˜„
                              https://media.giphy.com/media/3o6Zt2b3OThZOpG4py/giphy.gif
                              • cottyC Offline
                                cotty
                                applied to a sphere...
                                my SketchUp gallery
                                • HornOxxH Offline
                                  HornOxx
                                  wow Cotty !!!!!! - and I bet that "corncob hand grenade ball" you have sketched and so good rendered right now from the scratch - Thanks for this really really good example πŸ˜„
                                  • BoxB Offline
                                    What can I say, I like hooks.
                                    • cottyC Offline
                                      cotty
                                      And the hooks are just hooked up? πŸ˜‰
                                      my SketchUp gallery
                                      • BoxB Offline
                                        There is actually a pin sticking out at the bottom that would slip into a drilled hole in the board, so yes, in a sense they are just hooked into place but won't swing from side to side.
                                        • BoxB Offline
                                          Here's a couple of tables using an array of a single SUbD components.
                                          I suspect the first table should only be used to serve Jelly, or Jello as you yanks call it.
                                          The second would be far more stable.
                                          I think I will have to build them just to see how well they work in the real world.
                                          The first one as a proxy, the second can be created by flipping four components.
                                            Reminds me of this guy from the Snorks cartoon...
                                            https://ih0.redbubble.net/image.258227615.7489/flat,800x800,075,f.u1.jpg
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 82
                                            • 83
                                            • 58 / 83
