    SubD examples and models
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • andybotA Offline
      andybot
      @rich o brien said:
      here's a raygun model i was doodling with last week.
      now to finish texturing it...
      [attachment=0:2glttolj]<!-- ia0 -->Substance Painter_2017-07-14_21-32-24.png<!-- ia0 -->[/attachment:2glttolj]
      That's rendered in Sketchup, Thea? Texturing looks sweet, I gotta try out substance painter.
      • StinkieS Offline
        Stinkie
        Me too.
          That direct in the Substance Painter viewport. If you're half thinking of adding SP to your workflow don't waste time procrastinating it. Dive in. Best decision I ever made.
          The reason WrapR got kickstarted. SketchUp needed a better way to get UVs.
            Carto
            Hello Rich,
            Just a quick FYI...Substance Painter and associated software is on sale. That being said would you recommend just Painter or the entire Substance Pack?
            Regards
            • JQLJ Offline
              JQL
              Painter is used to directly paint materials (colors, height, roughness, normal, etc...) into a correctly UV unwrap mesh. You can also use ready made materials, with special effects that are affected by the shape of your mesh. You can also import textures and paint your mesh and there are other more advanced options. It's incredibly powerful at that but it really requires a UV unwrapped mesh without it it won't work.
              Designer is a material creation sofware that is also capable of texture your model. You can create materials procedurally or based on images, you can combine materials and texture your model. You can also apply effects that react to your model's geometry but you cannot handpaint your model.
              The materials used in painter are created with designer, but designer allows you to create materials for any software that uses bitmap textures for materials.
              Bitmap to Material is a very very "simplified version of Designer" where you can create materials from base textures for any render engine or software.
              Without knowing what you do, Rich cannot recommend any of the above. I would recommend designer for people that use sketchup and render software for stuff like architecture where you need to create materials even if you will eventually texture some of it using UV unwrap meshes.
              I would recommend painter for people that use sketchup for isolated objects as it's more likely that they are able to UV unwrap them. If you know that your texture process will eventually lead you to a UV unwrapped mesh, painter is definetelly worth it as you can see in the raygun above.
              I would recommend Bitmap to Material for people that will only search for images and convert them to materials.
              www.casca.pt
              Visit us on facebook!
                Carto
                Hello JQL,
                Thank you for the thorough explanation.
                Regards
                  JQL answered for me.
                  If Node based material creation is something you want to add to your skillset then Bundling Painter and Designer is a must.
                  As with all software considerations trials are the best way to decide. For Designer, you need to clear your workload to really see the benefits.
                  I recommend watching Sharpstance tutorials on YouTube.
                  But if you can source Substance materials online then the Substance Player is all you need.
                  Horses for courses.
                  • BoxB Offline
                    That is indeed a very impressive first post. Well done.
                      tengel07
                      My first post here 😎
                      I'm working on the B194 - Schueys first WC-Racer in Formula 1:
                      http://www.scaleautofactory.com/3dDesign/b194_001_quad.jpg
                      http://www.scaleautofactory.com/3dDesign/b194_002_quad.jpg
                      Based on a rough poly-model i redraw the car with QFT, SubD and VT.
                      Great tools.
                        Nice!
                        That's the one that was first to have that double-decker front nose wing, right?
                          At this step the front recalls old Bugati! πŸ˜‰
                          • N Offline
                            nlipovac
                            Impressive, RichΒ΄s gun and B194. WOW! Can wait to see B194 textured.
                              tengel07
                              More progress pics:
                              http://www.scaleautofactory.com/3dDesign/b194_003_quad.jpg
                              http://www.scaleautofactory.com/3dDesign/b194_004_quad.jpg
                              http://www.scaleautofactory.com/3dDesign/b194_005_quad.jpg
                              At least: Rear-Wing and Front-Suspension needs to be "Quaded"
                              Then UV-Wrapping and Texturing with WrapR-Beta...
                              • BoxB Offline
                                Coming along Nicely Tengel07
                                • BoxB Offline
                                  I found my Grandpa's old Oiler in the back shed and gave it a bit of a clean up, do you think it would be a suitable candidate for SUbDing?
                                    So you are from Aladin's family! πŸ˜„
                                    • BoxB Offline
                                      I gave it a go, what do you think, is it close?
                                      http://i.imgur.com/p8zSlNY.gif
                                        This is look VERY good!
                                          Did you share the original pic of the oiler somewhere?
                                          • BoxB Offline
                                            Not as far as I remember, but apparently someone did on farsebook.
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 82
                                            • 83
                                            • 48 / 83
