    [request] projection on curved surfaces
    17 Posts 9 Posters 2.3k Views 9 Watching
    • TAYEBIT Offline
      TAYEBI
      Although projection toolset is already available,it is only working on flat faces....
      By using SU's sandbox it is only possible to put geometry on z axis projection.....
      Thus, having something similar to Rhino's Projection which projects geometries on curved surfaces could affect users productivity is fundamental ways .
      It will be awesome if someone consider codding that tool and makes this kind of projection happen.
      πŸ˜„ πŸ˜„ πŸ˜„
      • TIGT Online
        My "Extrude Tools" - ExtrudeEdgesByVectorToObject...
        Does this of edges, projected along any vector.
        You will need to erase unwanted extrusion 'side' faces, but the outline 'projected' into the curved surface should be want you want...
        http://sketchucation.com/pluginstore?pln=ExtrudeTools
        http://sketchucation.com/forums/viewtopic.php?p=217663#p217663
        http://sketchucation.com/forums/viewtopic.php?p=331059#p331059
        • fredo6F Offline
          fredo6
          πŸ˜„ πŸ˜„ πŸ˜„
          VisuHole has some capability of stamping flat patterns on curved surfaces.
          Fredo
          • TAYEBIT Offline
            TAYEBI
            Oh thanks for your response ... both plugins you offered are great ....
            what I meant is something like TIG's one but without drawing any extruded faces ...
            ( and without lots of dialog boxes Like what we seen in some of your plugins ...πŸ˜„ πŸ˜„ πŸ˜„ ... Just keep it simple like bool operations of SU Pro )
            It Should done one simple task : extrude line from given shape to the average direction of target surfaces
            or to the direction of surface normal ( as a separate tool or option)
            then intersects extruded result with the target surface ..
            finally deletes extruded faces and just keep intersection lines ( welds it if possible ) ...
            I already do this task by using extrude lines by D.Bur and intersecting and deleting
            Rhino has two different methods: vector ( exactly like what I have mentioned before , and project by surface normal that deforms shape based on target surfaces ..
            I think both of you already have enough resources and written codes ..
            Dear TIG, you can do it by a little modifying to that extrusion tool: delete the extruded shape and just leaving intersection ( and make it more user friendlier πŸ˜‰ )
            Dear Fredo, I thing all it needs is already done in your reach library , just mounting them together can make a perfect projection plugin πŸ˜‰
            finally ... thank you for the time you spend for reading people wishes. you are great
            • cottyC Offline
              cotty
              One right-to-left selection and a delete key press is too much cleaning up for you?
              my SketchUp gallery
                Simplicity is always beautiful ! 😎
                • P Offline
                  pejmantayebi
                  [attachment=0:49gfo9yq]<!-- ia0 -->extrude.gif<!-- ia0 -->[/attachment:49gfo9yq]
                  πŸ˜„ πŸ˜„ πŸ˜‰ πŸ˜†
                  no its not too hard for me of any one else ... ( as I currently using same method in order to reach the result ) 😎
                  But let's answer a question : why people using a plugin for multi-face offset instead of double-clicking ? because It's far more simple ..
                  so having a specialized plugin could be much better than manual actions ..
                  In addition, the second normal method is not currently available ( as I know ) ..
                  as a result, having a general curve-projection plugin could be awesome.
                  πŸ˜‰
                  • sdmitchS Offline
                    sdmitch
                    Do you keep the original shape or delete it as Cotty did?
                    I'm a bit confused about what you mean about projecting using the surface normal or an average normal? It would seem to me that only the face normal or a defined vector to the surface would be usable.
                    http://sdmitch.blogspot.com/
                      @pejmantayebi said:
                      πŸ˜„ πŸ˜„ πŸ˜‰ πŸ˜†
                      πŸ˜‰
                      Perhaps you should get busy and write the plugin you want.
                      Why have you made two different profiles? That just creates confusion.
                      • P Offline
                        pejmantayebi
                        these videos shows what I mean :
                        http://docs.mcneel.com/rhino/5/help/en-us/commands/project.htm
                        http://docs.mcneel.com/rhino/5/help/en-us/commands/pull.htm
                        @ sdmitch : excellent ! Yes This is what I meant by fist method .. you are awesome ! .. the second method ( normal ) is like Rhino's PULL command that I mentioned it's link before
                        • sdmitchS Offline
                          sdmitch
                          Check your messages for a plugin to try.
                            Have you try VisuHole ?
                            • TAYEBIT Offline
                              TAYEBI
                              Yes I tried that plugin ... It's amazing ...
                              You know .. nowadays it's not impossible to fulfill our needs ..
                              Sdmith ... you are awesome ...
                              I will test it ..
                              If you decide to publish it , I can help you .. making Icons and vector Icons
                              so ... Is it possible to post that plugin on this account ?
                              thanks a lot
                              • TAYEBIT Offline
                                TAYEBI
                                HI Dear SDMithch ...
                                Thanks for your great work ...
                                first of All .. there are lots of reasons for a general purpose project plugin which is specialized on doing the projection job .. ( unlike fredo's or TIG's )
                                IT is the expanded Drape tool of sandbox ( SU's default project tool that only let do it on z axis )
                                It should have a fast ,simple and flexible User Interface that not limit user to having one face or grouped surface . it should work with separate lines , faces ( more than one ) , groups , etc...
                                and should let user do the projection without having to group target surface ..
                                the dialog boxes are not desirable . they disturb the user .. and should be replaced by status bar text or onscreen one . ( like thomthom's )
                                finally , nor the pull command or project are not working properly at the moment . as you see in the pictures, pull direction should be surface normal not UCS origin !! ..
                                in further versions, lots of options could be added :
                                • project by vector (see projection tools by D.BUR )
                                • project along UCS axis
                                • Project to the direction of average normal of target surface
                                • etc
                                THANKS AGANE FOR THE TIME YOU ARE SPENDING πŸ˜‰ πŸ˜‰
                                not limiting user having group .. dialog boxes are disturbing
                                pull command should use surface normal . although, the method of selecting point could be a variation . but the main purpos is pull to normal
                                in some cases project command not works
                                wile pus pull works !
                                • sdmitchS Offline
                                  sdmitch
                                  Your pictures indicate you are attempting to use the "Pull" not the "Project" function. As I explained in my PM, the "Pull" was currently limited to "surfaces" at the model origin and faces located above the surface.
                                  Surface normal? How do you calculate that with a spherical surface?
                                  I project by vector, the face normal, in the Project option.
                                  Project along UCS axis. How are you going to do that without those pesky "dialog boxes".
                                  project to the direction of the average normal. What it that points away from the surface?
                                  • TAYEBIT Offline
                                    TAYEBI
                                    hi
                                    Feredo's join push pull can create the vectors ..
                                    Is it forbidden to use codes or libraries from other authors ?
                                    by using the code it will become easier to reach that result..
                                    if it's impossible to use his code, I ask Fredo6 to develop the idea "General Purpose Projection tool" if he find it useful. he have enough resources and pro developed codes
                                    Very good πŸ‘ ... So it needs to be documented .. I didn't find that option ..
                                    There are lots of methods, having a toolbar with different options could be a usual one.
                                    UI.dialogbox is not such a
                                    some other methods are available : using some key shortcuts like tab for switching between options .. context menu ( like SketchUV or some A4u tools ) .. using on screen buttons or a launcher ( like feredo's )
                                    What I mentioned was just an Idea, In some cases It is hard to calculate that direction .. Specialty for closed surfaces like sphere .
                                    If you or any one else decide to write a general projection plugin, In his future versions, can consider it to intelligently do it . Add that option ( average normal ) only if the surface is not closed and based on rectangle (like those created with sandbox and its smoove tool )
                                    After all ... I just propose the Idea of the projection. since I use rhino, I find it good to have such option in SU ...
                                    SO do not engage with me .. or struggling ...
                                    If any one find it useful to write a extended version of SU's Drape tool, please Do it .. and If its better to achieve the result with using other methods like rotate and smoove, extrusion tools and delete, push pool along path and intersect, exporting to other softwares and import , etc ... so do not write the code . it is your decision.
                                    best wishes
                                    ![the join push pull already calculate required paths for "push" projection .](/uploads/imported_attachments/aE9T_Untitled.jpg "the join push pull already calculate required paths for "push" projection .")
                                      DreamPsi
                                      oh yeah um use lss_toolbar2.0 it has a function called stick group which I think is what you want . but if you have su 2016 or maybe 2015 that function wont work but I have found a work around for it ive posted on another topic
                                      http://sketchucation.com/forums/viewtopic.php?f=80%26amp;t=63567#p582194
                                      youll need to have notepad++ on order to find those line numbers to fix the code on but all you have to do is change like 4 words and save it and then it should work like a champ
