    Texture position bug
    15 Posts 5 Posters 7.4k Views 5 Watching
    • T
      tailgater
      I'm getting this bug on SketchUp 2016:
      http://imgur.com/oP0Wok6
      It has like two images showing and its confusing when editing.
        I can't see what you're referring to. Maybe you could post a better description.
        And please post images here on the forum so people don't have to go somewhere else to see them. Use the Upload attachment tab below the text window.
        • T
          tailgater
          On first image, it looked normal
          http://i.imgur.com/aitxxO8.png
          But when you enter texture position mode, it had two overlapping images: (look at the tip of the facade and/or the door )
          http://i.imgur.com/ED3YIYf.png
          Thus making it confusing to edit.
            Perhaps you could share the SKP file?
            • T
              tailgater
              I just test the texture position tool on an empty scene and the bug was not there. So this could be my .skp's fault.
              File was too big though. So I tried to delete a huge chunk of stuff.
              But then I found out the bug will occur if the object is too far from the center of origin!
              I'll just work with the workaround I just come up! But then this still need to be fixed. Thanks!
                So it's not a bug in SketchUp after all? It's a problem with your model?
                • T
                  tailgater
                  Nope. Its not my skp. I just tested it in an empty scene with a cube with texture. Moving that cube far away and use the texture position tool will create the bug.
                    How far away from the origin? Please share an example SKP file that demonstrates the problem.
                    Here's a cube nearly a mile from the origin. I don't see any problem.
                    • T
                      tailgater
                      Alright. My model is ~3000 meters far.
                      clinton louisiana compact.skp
                        The resolution of the image is reduced while editing to reduce load on the GPU but I don't see the double image you reported.
                        • K
                          kaas
                          On my laptop (with old Intel gfx) I see a small 'jump' in the texture as soon as I enter the component. So, just guessing here: could it be a limitation of the hardware? Do you use an embedded gfx solution or dedicated gfx card?
                          • D
                            driven
                            generally, it worked as expected on my mac...
                            however I did invoke the 'ghosting' by placing the yellow pin in certain positions...
                            hard to repeat, or I'd make a gif...
                            john
                            • T
                              tailgater
                              [attachment=0:1ip2r5ix]<!-- ia0 -->Screenshot - 12_6_2015 , 9_36_37 AM.png<!-- ia0 -->[/attachment:1ip2r5ix]
                              That's not a reduced image. That is exactly the double image I'm saying!
                              I have no knowledge about graphics card but I'm on a Windows 7 laptop from 2009 or 2010. ATI Mobility Radeon HD 5145 and it says its dedicated.
                                It's not a double image but your computer must be displaying something different than mine is.
                                • S
                                  slbaumgartner
                                  Um, could there be confusion about the fact that the texture position tool tiles the material over a plane, so that you can see how it will repeat/tile depending on where you position and scale it?
