Help! - Curve Stitcher
Jesus,
what happened to all the useful plugins! Does anyone know of a curve stitcher plugin for Sketchup 2015? -
@aclark said:
Jesus,
what happened to all the useful plugins! Does anyone know of a curve stitcher plugin for Sketchup 2015?Well, I'm not Jesus but maybe I can answer your question. Have you tried Curviloft? It would probably be able to do what you want. Or TIGs Extrude tools? Those would be a good start anyway.
Try Rick Wilson option
curvestitcher21
http://www.crai.archi.fr/rld/plugin_details.php?id=93 -
Select the bottom curve of the handrail.
Use my ExtrudeEdgesByVector.
Click on the start of the curve and move the ghost-extrusion vertically up and snap on the end of the upper part of the handrail-path.
Confirm and the line is extruded into a curving 'surface'.
Use Fredo's JJP on it to add some thickness... -
I often try to use Extrude Edges by Vector before other tools. This should have been a standard SU tool. It's push-pull for edges.
Register LoginAdvertisement
