    AmbientOcclusion for SketchUp released
    extensions
    42 Posts 15 Posters 15.9k Views 15 Watching
    • F Offline
      fluid
      We are glad to announce the release of AmbientOcclusionfor SketchUp.
      AmbientOcclusionis a very fast visualization plugin that requires no learning. In just one click, you will create a visually compelling preview of your 3d models, highlighting space and relations among objects.
      You can download a free 15 days trial here.
        Is this baked into a realtime model? Or a rendered still?
        I'm trying to figure out how this differs from already existing tools.
        • F Offline
          fluid
          Calling it a renderer would be a little too much... It does just one thing, real-time ambient occlusion in one click. No materials or lighting to tweak. It's just a simple tool for people that need a nice and quick visualization without having to learn (and spend for) a full rendering software.
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            The result is displayed in a seperate window, not the Sketchup viewport, right?
            • F Offline
              fluid
              Yes, unfortunately the SketchUp api doesn't allow to render directly into the standard viewport
              • PixeroP Offline
                Pixero
                Isn't that what LightUp does?
                  jiminy-billy-bob
                  Within a custom Tool, you can draw in the viewport. http://www.sketchup.com/intl/en/developer/docs/ourdoc/view#draw2d
                  Tomasz from Thea Render even found a way to inject the render in the assembly to be able to see the render in the viewport while using any tool. But that's another master level πŸ˜„
                  • jujuJ Offline
                    juju
                    I'm trying to figure out how this differs from Visualizer...
                    • mariochaM Offline
                      mariocha
                      Repeated BUGSPLATs, on Windows 7 under Parallels. πŸ˜•
                      %(#008000)[Mario C.
                        jiminy-billy-bob
                        Visualizer is a true renderer (although very limited features). This is "just" Ambient Occlusion.
                        It could actually be very interesting if it was happening in the viewport. For client presentation/interaction, etc
                        Sometimes you just want to add some depth to the model without a realistic render.
                        • pbacotP Offline
                          Is the blur in the last image a part of the plugin's function or post pro?
                          • F Offline
                            fluid
                            The blur is a ray-traced depth of field done directly by the plugin (in the pro version)
                            • FrederikF Offline
                              Frederik
                              Thea4SU is also able to do this, hence you're wrong, Nicola...
                              Cheers
                              Kim Frederik
                              • F Offline
                                fluid
                                Thanks for pointing that out, we'll look into it for the upcoming release
                                • F Offline
                                  fluid
                                  We just did a new release, fixing the Bugsplat that some users were experiencing. You can get it here
                                    sepo
                                    Hmmm...The output looks like Podium version 1.x with no lighting and AO preset. I remember it well as wrote a preset and it was damn fast. If is not real time in the SU viewport it is step backward IMHO.
                                    • pbacotP Offline
                                      What would realtime in the SU Viewport mean? You could view your models like this while navigating and working on them?
                                      • olisheaO Offline
                                        olishea
                                        would be cool if it baked the textures
                                        oli
                                          πŸ‘
                                          • jujuJ Offline
                                            juju
                                            @fluid said:
                                            We just released a new version of AmbientOcclusion, you can get it here: http://www.ambientocclusion-sketchup.com
                                            This new version adds rendering directly inside the SketchUp viewport.
                                            [flash:7ci503sq]https://www.youtube.com/v/Rst3-SoYAvA[/flash:7ci503sq]
                                            nice...
                                            • 1 / 3
